type II power steering pumps #2467740
03/17/18 02:34 PM
03/17/18 02:34 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
so, im adding power steering , i have a mustang II rack.. what GM pump will bolt to my hemi with least amount of work?
Re: type II power steering pumps [Re: mcat4321] #2467990
03/18/18 04:13 AM
03/18/18 04:13 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You can whip up a 1/2" plate adapter pretty quickly.
All of the GM Type2 pumps have the same bolt pattern, none of which will "bolt-on" to your Hemi.
I have a Type2 PSC pump on my 5.7L.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: type II power steering pumps [Re: mcat4321] #2468014
03/18/18 10:09 AM
03/18/18 10:09 AM
Australia
aus370 Offline
aus370  Offline
Australia
I got my pump from Tuff stuff, pn 6175ARES , and used a Dorman pulley pn 300-126. And a pic of the bracket i whipped up .
Re: type II power steering pumps [Re: mcat4321] #2468032
03/18/18 11:09 AM
03/18/18 11:09 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
here's mine. I use it for my torque strap mount as well.
15621593_1380993425278045_408940761443031503_n-2.jpg15781555_1397717560272298_1191315005418106474_n-2.jpg
2020 RAM 1500
Re: type II power steering pumps [Re: GoodysGotaCuda] #2468095
03/18/18 01:52 PM
03/18/18 01:52 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
so, .500 is the magic number on thickness?
Re: type II power steering pumps [Re: mcat4321] #2468201
03/18/18 06:16 PM
03/18/18 06:16 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That's what mine is, with a Dorman 300-313 pulley.
However, I should have bought a larger diameter p/s pulley, the 5.5" is a little small at 6,000 crank rpm.
2020 RAM 1500
Re: type II power steering pumps [Re: mcat4321] #2468479
03/19/18 09:18 AM
03/19/18 09:18 AM
Australia
aus370 Offline
aus370  Offline
Australia
Ha my bracket looks crappy compared to Goodys .
I made mine after seeing pictures of TINCUP's on forAbodys only forum 3 years ago .
1/2 " thick is about right , it depends on pulley used , back space , how far it's pressed onto shaft . you'll figure when you've got the parts.
Re: type II power steering pumps [Re: mcat4321] #2474316
03/30/18 12:03 PM
03/30/18 12:03 PM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
I'm needing a p/s pump as well but I'm doing a remote reservoir due to having hydro boost brakes. Are both of your brackets pre Eagle? I have an Eagle and was wondering how crucial is the placement of the pump? I'm using a Tuff Stuff 6170ALB with AN fittings on both ports.
"It's funny how one project eventually leads (or forces) you into another one.
It's really just one endless project designed to induce insanity and bankruptcy."
Re: type II power steering pumps [Re: mcat4321] #2474823
03/31/18 11:55 AM
03/31/18 11:55 AM
Australia
aus370 Offline
aus370  Offline
Australia
The pulley you choose needs to clear the closest part, which is the tensioner .
And the spacing of the pump from the cylinder head needs to line pulleys up , so it dosen't throw the belt .
Re: type II power steering pumps [Re: aus370] #2474839
03/31/18 12:21 PM
03/31/18 12:21 PM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
OK Thanks. Do you have a picture of yours installed?
Re: type II power steering pumps [Re: kpzbee] #2474872
03/31/18 01:49 PM
03/31/18 01:49 PM
Australia
aus370 Offline
aus370  Offline
Australia
Re: type II power steering pumps [Re: aus370] #2475140
04/01/18 12:37 AM
04/01/18 12:37 AM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
Very nice!! Thanks.
