Re: Gen III power steering pump fittings?
[Re: moparcyco]
#2474776
03/31/18 10:19 AM
03/31/18 10:19 AM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
I use the same pump. I cut the stock pump side hose/line off, leaving enough metal tube to use a compression fitting on. Then I cut the vehicle side hose off and had my local hydraulic shop crimp an end on the hose that would tie in to the pump side line. Gates part G50510-0606. That fitting is made specifically to crimp onto a 3/8” power steering hose and the other end to tighten onto a 3/8” hard line...
SuperBeast
An enforcer for the Mopar Mafia!
[Re: sycboi]
#2474813
03/31/18 11:31 AM
03/31/18 11:31 AM
Posts: 124 Colorado
MoparCar
Colorado
Take a look at this on Bouchilllon's site. They have a fitting to adapt to an AN. Is this what you are looking for? The fitting they list is on their power steering parts section. If the link doesn't work, go to their site and find the 6.1 power steering pump for sale. http://www.bouchillonperformance.com/inc/sdetail/6706/6714Wes
[Re: sycboi]
#2474895
03/31/18 02:46 PM
03/31/18 02:46 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I use the same pump. I cut the stock pump side hose/line off, leaving enough metal tube to use a compression fitting on. Then I cut the vehicle side hose off and had my local hydraulic shop crimp an end on the hose that would tie in to the pump side line. Gates part G50510-0606. That fitting is made specifically to crimp onto a 3/8” power steering hose and the other end to tighten onto a 3/8” hard line... ' I did similar on the last swap. Flared the 5.7 hemi pump hard line and cut/flared the original line from the coronet and used a fitting to connect. Basically like connecting a brake line section only bigger.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
