Milling 03-08 Hemi heads Questions #2473807
03/29/18 01:04 PM
03/29/18 01:04 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Has anyone Milled the early heads to make them close chamber. If so what CC did you end up with?
Thx Matt
Re: Milling 03-08 Hemi heads Questions [Re: MattW] #2473841
03/29/18 02:49 PM
03/29/18 02:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Can't tell you the CC,but I had a set of Iron heads that were milled to the point that when torqued down I was blowing head gaskets due to flex.Put on a set of virgin heads,problem solved.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Milling 03-08 Hemi heads Questions [Re: MattW] #2473871
03/29/18 04:11 PM
03/29/18 04:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
There was a guy on here who welded up that area and milled em flat, I think your going to get too thin if you milled them that much.
Probably gonna be close to the price of a set of used eagles anyhow.
