8 3/4 question #247384
03/08/09 09:58 PM
03/08/09 09:58 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
I just picked up a 742 center section with a clutch suregrip in excellent condition.I would like to change the gear ratio and swap it with my 489 case.Do I need to change anything(bearings)in my housing or can I bolt it in and go?
Re: 8 3/4 question [Re: gch] #247385
03/08/09 10:06 PM
03/08/09 10:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 742 and 489 carriers use different size pinions,
contact Dr Diff for some help/parts. If you go to the
489 carrier use the solid pinion spacer instead of
the crush sleeve
