AFG sensor placement #2473216
03/28/18 10:16 AM
03/28/18 10:16 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Just picked up a AFG that I will be using for my drag car. Where is the idea placement for the sensor? I'm running TTI underchassis headers with a 18" glasspak muffler welded to a short piece of exhaust pipe that is welded to a collector ring that is bolted to the header. On the pass side I have a evac tube with breather in valve cover hooked into the collector portion. On the driver side I don't have anything hooked up.
If I installed on the passenger side would the breather mess with the sensor?
Also what is the idea AFG reading? I'm running 3 gal 93 with 2 gas 110 mix = 100 oct.
Re: AFG sensor placement [Re: DusterKid] #2473301
03/28/18 01:34 PM
03/28/18 01:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Try to get the O2 set about 3" behind the collector
end(where the primary tubes ends).. you want the
air thats coming out of the primaries.. put them
in ahead of the breathers so you dont get a bogus
reading... also make sure they are angled downward
so they can drain any moisture.. you want them
below 9 clock and 3 to drain
EDIT
there isnt a true AFR reading.. for cruise you
would like in the lower 15 range..for WOT it
somewhere in the upper 13s.. I dont use them to
get a idle reading(I want the best idle I can
get thats clean)your car may want numbers a
little different
wave
