Trick Flow heads - thread inserts?
#2472631
03/27/18 06:04 AM
03/27/18 06:04 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
Do the TF heads come with thread inserts (Heli coil)? If not would you add them to all/some bolt holes (exhaust, Intake, rocker shaft, valve cover)? I think I'd go with Time-Sert inserts or E-Z Lok instead of heli coils.
Re: Trick Flow heads - thread inserts?
[Re: DGS]
#2473016
03/27/18 10:39 PM
03/27/18 10:39 PM
dartman366
Mt. Vernon, Ohio
Do the TF heads come with thread inserts (Heli coil)? If not would you add them to all/some bolt holes (exhaust, Intake, rocker shaft, valve cover)? I think I'd go with Time-Sert inserts or E-Z Lok instead of heli coils. I wouldn't do any unless needed, I checked all of my threaded holes with thread go/no go gages and all were spot on for sizing, everything went together as expected, appropriate thread lubricant is suggested.
[Re: DGS]
#2473043
03/27/18 11:15 PM
03/27/18 11:15 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I agree with dartman, lube threads, all good.
1963 Plymouth Max Wedge 1971 Barracuda
