Re: Rear main seal retainer, what is a quality piece?
[Re: RV2]
#2472606
03/27/18 02:37 AM
03/27/18 02:37 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
What block, type of motor, are you wanting one for?
[Re: RV2]
#2472749
03/27/18 01:51 PM
03/27/18 01:51 PM
Cab_Burge
I have used stock ones in stock blocks forever with no problems, do you have a stock retainer to mock it up with? If so try looking at it to see if it will work or not
[Re: Cab_Burge]
#2472795
03/27/18 03:14 PM
03/27/18 03:14 PM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
Never had a problem w/ stock retainers.
[Re: RV2]
#2472846
03/27/18 04:48 PM
03/27/18 04:48 PM
an8sec70cuda
Never had a problem w/ stock retainers. Chip is that what you have in your Hemi? No, the KB block has it all made in one piece as the rear main cap. The World blocks come w/ a new retainer. All my stock block builds I use stock retainers. Don't see any need for a new one.
[Re: an8sec70cuda]
#2472856
03/27/18 05:18 PM
03/27/18 05:18 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
From my experience, used factory retainers sometimes get distorted from having the rope seal pounded into them and don't work well with the neoprene seal. Get a new one.
[Re: John_Kunkel]
#2472870
03/27/18 05:43 PM
03/27/18 05:43 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
I never had any issues with just using a stock real main seal retainer either. I do currently have a billet retainer in my Hemi though. No issues so far with this one either.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: RV2]
#2472960
03/27/18 08:12 PM
03/27/18 08:12 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
The mancini one fixed a very pesky rear main seal leak for me & others have that exact same style. I'm not sure why it worked, but I'm sticking with it. I also used the silicone 2-piece seals, the good side seals, assembly lube, VERY thin smear of RTV on the mating surfaces & offset the seals. Check Hughes Engines, I believe they carry the same rear seal retainer. I used their directions for installation.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: RV2]
#2472978
03/27/18 09:11 PM
03/27/18 09:11 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
I have never had an issue with a stock piece, even in aftermarket blocks. My Predator has a stock retainer in it. I don't use side seals either just silicone. As pointed out pre checking them before the seal is installed will usually identify any potential issues.
