Bang-for-buck street protection - oil pan or accumulator?
#2472385
03/26/18 05:20 PM
03/26/18 05:20 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I have been spending a lot of hours replacing the rest of my car's suspension - which has me turning to the stock mid-sump small block oil pan I have on my motor (late 90s 318 in a 67 Coronet)
I'm never going to run this car very hard, maybe an autocross at most - otherwise just some backwoods fun. But I don't want to cause myself problems from cornering or braking starvation if it's a possibility with a stock pan. I can see how the oil can slop forward away from the pickup currently.
However, I also don't want to run a road race pan for the sake of ground clearance - if I were to change the pan, I'd want a trapdoored/baffled stock mid-sump, not an 8 qt with kickouts. However, nobody seems to outright sell these things so I don't know where to start with that option.
This is what makes me curious about an accumulator - just a basic type plumbed in through a sandwich plate.
Does this make sense for my application or do the failure risks involved with running the lines to/from the accumulator not make sense for street use?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Bang-for-buck street protection - oil pan or accumulator?
[Re: Secret Chimp]
#2472388
03/26/18 05:33 PM
03/26/18 05:33 PM
Posts: 701 Northern California
lilcuda
Northern California
Here's my two cents. I owned the "Red Brick" aka "Tim's Valiant" for a couple of years and only drove it on the street. It has an Accusump as well as a road race pan. One of the advantages of the Accusump is that you can prime the oil system before you crank it. Great for when the car sits for a long time. The oil lines can leak. I had a one medium size leak that I fixed by re-sealing the connection. The Accumsump makes oil changes a bit more of a task, but not too involved. If you really don't want to mess with a road race pan, it is a good alternative. Spend the money for the electric valve. Makes it much easier to deal with.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: Secret Chimp]
#2472417
03/26/18 06:12 PM
03/26/18 06:12 PM
Secret Chimp
Eugene, Oregon
I haven't spent the bucks on a MIG yet (I have no idea how to and I'd be teaching myself, so good reason!) but otherwise I would've done that already, indeed. Probably should've noted why I haven't just done that yet..
[Re: Secret Chimp]
#2472578
03/27/18 12:41 AM
03/27/18 12:41 AM
Secret Chimp
Eugene, Oregon
Man, I knew I was forgetting an option when I was circling back to this. That's not a bad price for the features. I should've bought a Kevko pan when I swapped this thing originally. Thanks!
[Re: BigBlockMopar]
#2473394
03/28/18 04:58 PM
03/28/18 04:58 PM
Posts: 5,385 Pikes Peak Country
TC@HP2
Pikes Peak Country
I doubt you'll need an accumulator. It will be hard to find a nice road racing pan for a mopar. I'd think a nice 6qt pan with some trap doors would work well enough. The Milodon pans are pretty nice. They are darn near a custom piece with an off the shelf price. I've done that on several cars. Even if you don't have a welder, if you trim up a piece of steel sheet fromteh hardware store and have it welded in at the local shop, you are talking about a less than $20 modification to ensure the pick up stays covered.
[Re: Secret Chimp]
#2476737
04/03/18 01:15 PM
04/03/18 01:15 PM
Posts: 1,440 NW Chicago suburban area
Mopar Mitch
Too bad MaMopar didn't produce the factory stock oil pans with simple horizontal baffles similar to as shown. I had that done (by a fellow Mopar experienced road racer/autocrosser who showed me his own) to my own oil pan nearly 40 years ago when I began autocrossing. This was the absolute best engine modification ever done to any of my engines -- allows retained oil pressure under hi-g-force cornering, acceleration and deceleration.
The best reason to use an Accusump would be for pre-oiling after long sitting time periods. I actually have a new 3-qt Accusump and most of the required items to install, just never got around to it. Truly, I've done without it for over 40 years of very serious competition AXg (pylon, HSAX/HPDE, etc).
During my current new engine rebuild (small block), I'm considering installing it this time around. Possibly with a ~25 psi valve to activate it while engine is running IF it would ever run below ~25 psi. All considerations being thought of, as well as location and plumbing. Its still a street-driven car, but used primarily for wknd track events (mostly HPDE/HSAX, maybe returning to pylon autocrossing in the future).
I'd like to see some pictures of cars with an Accusump installed -- location, set-up details, etc. Engine bay location adds weight to the front end (not desirable, but convenient). Interior? Trunk? Remote filter location? Electronic solenoid valve location? Activation light?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2476896
04/03/18 05:39 PM
04/03/18 05:39 PM
lilcuda
Northern California
I'd like to see some pictures of cars with an Accusump installed -- location, set-up details, etc. Engine bay location adds weight to the front end (not desirable, but convenient). Interior? Trunk? Remote filter location? Electronic solenoid valve location? Activation light? Mitch, here is a picture of the Accusump in "Tim's Valiant". It has the electronic valve. THe lines run along the passenger side sill and up under the dash, through a plate over the hole where the heater fan used to be. The gauge on the Accusump stays close to the same pressure as the gauge on the dash, so no need to have a valve that opens at 25 psi. If the engine oil pressure drops, the Accusump automatically dumps its contents into the engine.
[Re: lilcuda]
#2477432
04/04/18 03:52 PM
04/04/18 03:52 PM
Mopar Mitch
T/Anks Lilcuda for the pic... IF I had a roll bar setup I'd consider something like that.
Mopar Mitch
[Re: RylisPro]
#2477466
04/04/18 05:18 PM
04/04/18 05:18 PM
lilcuda
Northern California
Isn't that a Moroso Accumulator in the pic? Exactly the same thing as Canton's Accusump but in a silver can instead of blue. I wouldn't mount an Accumulator/Accusump on a roll bar like that if I had room further back and lower on the floor as it helps with weight distribution and center of gravity. I mounted mine where the rear bench seat used to be. I don't have a good pic of it but you can see it make a cameo in my camera mount video on YouTube. The AN-12 line is plumbed and runs by the passenger seat to the engine bay. Yes, I believe it is the Moroso Accumulator. I refer to it as an Accusump incorrectly, like many people refer to all tissues as Kleenex. Not sure why it was mounted that way. I guess so that the gauge was readable by looking over your shoulder. I was never fully comfortable with it in that spot, thinking that a leak could be quite messy and possibly painful if it sprayed around in the passenger compartment, but since I no longer own the car, it's not my problem. :-)
[Re: Secret Chimp]
#2477509
04/04/18 07:19 PM
04/04/18 07:19 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
That's an Accusump. It used to be the difference was that Canton's used a schraeder valve for a preload of airpressure behind the piston. IIRC Moroso's had a hemispherical end and that had to be pointed upward. Canton Accusmps's were raw finish for years.
