Washer bottle whats the difference from an original & repro
#2470956
03/23/18 02:22 PM
03/23/18 02:22 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
70 A Body Washer bottle whats the difference from an original & repro Thanks
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: Washer bottle whats the difference from an original & repro
[Re: 71birdJ68]
#2470989
03/23/18 03:35 PM
03/23/18 03:35 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Why are some pure white, and the same bottle is available in off white, almost a yellow color? That is so it can look old but still hold fluid, for unrestored cars.
[Re: Neil]
#2471072
03/23/18 07:21 PM
03/23/18 07:21 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
I bought one for a 70 Swinger and the holes don't line up with the original. Not sure if it shrunk, or was just made wrong? Had the same problem with the one I used on my Duster.
[Re: davesmopars]
#2471109
03/23/18 08:30 PM
03/23/18 08:30 PM
davesmopars
cheshire, ct
Not sure about the off white thing I think the original were white also and just turned color after time. The only reason I think this is. I had a 69 Valiant that I sold the hood and the car sat outside with the original washer bottle(filled with water fluid), the washer bottle all nasty and yellowed it turn perfectly white after time(months of sitting in the weather and sun) It looked new I could not believe it.
[Re: davesmopars]
#2471113
03/23/18 08:33 PM
03/23/18 08:33 PM
davesmopars
cheshire, ct
So on repro ones the date codes and all the stampings are correct. So far just the mounting holes are off on the 70 A bodies ones and on the B body ones the cap opens the wrong way.
[Re: davesmopars]
#2471150
03/23/18 10:29 PM
03/23/18 10:29 PM
Posts: 499 Nanuet, NY
johntpr
Nanuet, NY
The black caps are wrong too. The tops are too flat and the circle pattern like on originals isnt there.
69 Daytona 4 speed
[Re: davesmopars]
#2471179
03/24/18 12:14 AM
03/24/18 12:14 AM
Posts: 306 Georgia
69bfan
Georgia
On the 68 to 70 B-Body reproduction washer bottle, the cap opens in the correct direction as they were issued in the 68 to 70 time frame. In the mid 70's, Chrysler over the counter washer bottle had the cap moved to the opposite side. From what I was told, the move was made so that there would be less likely a chance for the lid to be blown open from air disturbance from the radiator or outside air entering into the engine compartment. These bottles were sold in that fashion up through the late 80's. During the mid 80's some bootleg washer bottles did get out of the manufacture with the lid opening in the correct fashion. The reproduction bottles, no matter the application, do have a date code. Each one has a particular date that does not change, where as assembly line pieces varied on a daily basis. As mentioned, the original washer bottle lids has a very slight lip that produces a circle pattern about the size of a quarter on the top. The over the counter washer bottles had on the lid, "Washer Fluid" spelled out. Also, on some of the A-Body washer bottles, the over the counter counter bottles are significantly heavier than the originals. So there are some subtle differences as compared to the assembly line to the over the counter to the reproduction piece on all of the different washer bottles.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
