Pushrod Length Checking #247057
03/08/09 04:03 PM
03/08/09 04:03 PM
U.S.
moparniac Offline OP
U.S.
I am ordering my new pushrods monday and I have always put the #1 piston at TDC and used a adj pushrod checker and torqued shafts/rockers down to 25lbs and also set cam lash to get actual pushrod length needed...... is this the preferred method.. thx
solid roller setup
Mopar Performance
Re: Pushrod Length Checking [Re: moparniac] #247058
03/08/09 04:15 PM
03/08/09 04:15 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Not for me. Check the intake when ex is just starting to open, and the exhaust when the intake is just passed fully open. But some rollers are a bit different
Re: Pushrod Length Checking [Re: moparniac] #247059
03/08/09 04:18 PM
03/08/09 04:18 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I would check it when the #1 exhaust starts to open. That way you know everything is at close on the Int side
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Pushrod Length Checking [Re: DemonDust] #247060
03/08/09 08:39 PM
03/08/09 08:39 PM
U.S.
U.S.
why is that? when you set valve lash 90*'s at a time starting at TDC ???
Mopar Performance
Re: Pushrod Length Checking [Re: moparniac] #247061
03/08/09 11:16 PM
03/08/09 11:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thats book learnin... If the you check the intake just as the exhaust starts to open & check the exhaust as the the intake is almost closed you are 100% assured the lifter your checking is on the base circle....
Grab a camshaft & look it over you'll see why this method is more accurate than the book method..
