Another cooling question #247024
03/08/09 02:53 PM
03/08/09 02:53 PM
Finally a HUSKER again
Moparnut426 Offline OP
Can most electric fans be switched fron a puller to a pusher?? I have a flex-a-lite trimline fan, and I am not running a echanical fan, just the electric one, and I want to run both next summer. It says reversable, but What wires do I switch?? I cant seem to find any of my wireing diagrams from when I initially wired it up.
Kasey
Re: Another cooling question [Re: Moparnut426] #247025
03/08/09 03:06 PM
03/08/09 03:06 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I know Spal fans need a reverse or proper fan for their motor...
I dont know about other manufactures except that if you switch the leads to the fan motor it will run the other way....
look yours up on line and see if they have directions or info for yours;;
I have switched leads aroung on fan motors with no problems but it all depends on the design of the fan...
