Re: what carb on 69 roadrunner
[Re: 2abodymcodes]
#2118738
07/27/16 12:32 AM
07/27/16 12:32 AM
Posts: 304 Wisconsin
Big D A12
Wisconsin
Assuming it is a non air car, here is a bit more detail for you.
Carter AVS 4 BBL 383 Auto Non/AC #4682S part number 2946595
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: 2abodymcodes]
#2477713
04/05/18 02:21 AM
04/05/18 02:21 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
What if shafts are frozen?? Can you fix them??
That's a case by case but USUALLY, yes. These are 409 Chevy carbs, they were solidly frozen. The shafts were so rusted and frozen that they had to be destroyed and cut out in pieces which was required to save the castings, the carbs ended up being really nice in the end. There was an extra cost for the required replacement core parts.
[Re: 2abodymcodes]
#2477899
04/05/18 02:07 PM
04/05/18 02:07 PM
Posts: 20,748 A collage of whims
topside
A collage of whims
There were different #s, depending on AT or 4-speed, AC or non-AC, Calif (1 centered mixture screw) or 49-state (2 mixture screws). (4615, 4616, 4638, 4682, 4711) Back in the day, some of us would swap a 440's AVS on. (4617, 4618, 4640)
[Re: topside]
#2477923
04/05/18 02:48 PM
04/05/18 02:48 PM
Posts: 3,373 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Holleys started on the 1970 383 Roadrunners--Carter before that.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
