1956 pickup mustang 2 oil pan clearance #2467768
03/17/18 04:04 PM
03/17/18 04:04 PM
S.florida
Jupiter331 Offline OP
S.florida
56 pickup with a 305 Chevy. Just put street rod engineering front suspension. I have a problem with the oil pan clearing it . Anyone deal with this or possible idea's for oil pan
Re: 1956 pickup mustang 2 oil pan clearance [Re: Jupiter331] #2467855
03/17/18 08:35 PM
03/17/18 08:35 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
Is the sump of the oil pan at the rear of the engine?
Re: 1956 pickup mustang 2 oil pan clearance [Re: Jupiter331] #2467868
03/17/18 09:07 PM
03/17/18 09:07 PM
S.florida
S.florida
Yes it's hitting the new crossmember
Re: 1956 pickup mustang 2 oil pan clearance [Re: Jupiter331] #2468012
03/18/18 09:49 AM
03/18/18 09:49 AM
mn
flyman Offline
flyman  Offline
mn
Problem is the wrong engine
Re: 1956 pickup mustang 2 oil pan clearance [Re: flyman] #2469247
03/20/18 05:14 PM
03/20/18 05:14 PM
dogdays Offline
dogdays  Offline
In general, each engine family will have front sump, center sump and rear sump oil pans. There is a different pickup tube for each style.
As this is a Mopar site, you'll have trouble getting anyone to tell you much about a smallblock Chevy oil pan. Plus, the location of the new suspension crossmember must be taken into account. We aren't knowledgable about that either.
You have already started catching flak for putting a non-Mopar engine in a Mopar vehicle. Sorry, that will certainly happen.
R.
Re: 1956 pickup mustang 2 oil pan clearance [Re: dogdays] #2469282
03/20/18 06:25 PM
03/20/18 06:25 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
64 thru 67 Chevy II 283 and 327 used a front sump pan and a different pump with a long pick-up that matches up with only that pan and pump.
