Re: 8 CW BBM cranks
[Re: Hemi_Joel]
#2470282
03/22/18 11:08 AM
03/22/18 11:08 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
16 CYL MILLER NORMAL ROTATION
A Miller V-16? AFAIK, Miller only produced 1 car v16 and a pair of marine v-16's. How you you end up with a crankshaft for one "in stock"? Strange!
I am sure there is a "story" that goes with this. It would be interesting to hear it.
Re: 8 CW BBM cranks
[Re: dwayne welder]
#2470851
03/23/18 09:49 AM
03/23/18 09:49 AM
Posts: 4,040 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Tell me different I have a Callie's crank here 4.000 stroke for a LS and has center counterweights??????? Respectfully, I don't understand the question. I am not necessarily pointing to one or more companies improper design. But the link was given by someone else here, thank you Alan, the one I was referring to to help you make your own decision.
Re: 8 CW BBM cranks
[Re: sgcuda]
#2472013
03/25/18 10:19 PM
03/25/18 10:19 PM
Posts: 6,136 Melbourne , Australia
LA360
Alan, just out of curiosity, what kind of weight and average power are the Pro Stock's these days. Is there a lean towards Lenco's or Liberty's? I don't recall what their minimum weight is, it's around the 2300 lbs from memory. They basically all run a Liberty Equalizer clutchless 5 speed now. Years ago some guys ran a G Force trans, but they can't handle the power they make now. I don't think they've run Lenco transmissions since Bob Glidden was racing. Power wise, I've not done the math, it would be around the 1500 hp mark somewhere.
Alan Jones
Re: 8 CW BBM cranks
[Re: LA360]
#2472171
03/26/18 08:51 AM
03/26/18 08:51 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I don't recall what their minimum weight is, it's around the 2300 lbs from memory. They basically all run a Liberty Equalizer clutchless 5 speed now. Years ago some guys ran a G Force trans, but they can't handle the power they make now. I don't think they've run Lenco transmissions since Bob Glidden was racing. Power wise, I've not done the math, it would be around the 1500 hp mark somewhere. Thanks. I plan on running Nostalgia Pro Stock and just wanted to know how my combo would stack up with the big dogs vs the old timers in N P/S.
