Pertronix distributor with Eddy heads? #2468824
03/19/18 10:51 PM
03/19/18 10:51 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Looking at using the Petronix 3 distributor with the Eddy heads on my 440. Guy in the parts store says there's a note in their catalogue that says aftermarket heads may need to be ground down to make clearance for the distributor. He then said it's an older catalogue. I thought Pertronix had reduced the diameter of their newer distributors to avoid just this. Anyone using a Pertronix with Eddy heads?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Pertronix distributor with Eddy heads? [Re: busboy] #2468838
03/19/18 11:14 PM
03/19/18 11:14 PM
PA
Cudaful Offline
Cudaful  Offline
PA
I had to trim some down on my 440 source heads with my Pertronix 3 billet, wasn't a big deal.
Re: Pertronix distributor with Eddy heads? [Re: busboy] #2468842
03/19/18 11:28 PM
03/19/18 11:28 PM
PA
Cudaful Offline
Cudaful  Offline
PA
Found a pic, should have taken a pic before I painted it but it's between the two bolt holes on the head.
Re: Pertronix distributor with Eddy heads? [Re: Cudaful] #2468843
03/19/18 11:30 PM
03/19/18 11:30 PM
PA
Cudaful Offline
Cudaful  Offline
PA
2
Re: Pertronix distributor with Eddy heads? [Re: Cudaful] #2468872
03/20/18 12:26 AM
03/20/18 12:26 AM
busboy Offline OP
busboy  Offline OP
Thanks for the pics Cudaful, I was thinking there was more to it than that. Very helpful up
Re: Pertronix distributor with Eddy heads? [Re: busboy] #2468885
03/20/18 12:57 AM
03/20/18 12:57 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I had to grind a lot of material from my RPM heads to get the Pertronix to fit. In fact, it was so much I was afraid I was going hit water, so I started grinding the distributor housing instead. twocents
Re: Pertronix distributor with Eddy heads? [Re: busboy] #2468897
03/20/18 01:40 AM
03/20/18 01:40 AM
PA
Cudaful Offline
Cudaful  Offline
PA
Mine was a 383 block so I don't know if it makes a difference. Best to call Pertronix but I love the distributor, fires up instantly.
Re: Pertronix distributor with Eddy heads? [Re: busboy] #2468958
03/20/18 08:47 AM
03/20/18 08:47 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve done two conversions on regular mopar distributors to the Pertronix. Both are easy to convert and look stock on a restoration. Man they start great compared to the points and the Mopar ECU. The first thing I noticed in driving the last one was the car ran much smoother. Converting the electronic distributor is easier and road repair would be very simple if you carry a spare unit.
Re: Pertronix distributor with Eddy heads? [Re: fastmark] #2469472
03/21/18 12:20 AM
03/21/18 12:20 AM
busboy Offline OP
busboy  Offline OP
Good suggestion fastmark, I used a Pertronix conversion on a stock distributor on my slant six car, worked great! Really wanted the rev limiter function with the P3 for this 440 in my 4 speed car but converting the guts of the original distributor may do for now.
Re: Pertronix distributor with Eddy heads? [Re: busboy] #2469591
03/21/18 10:04 AM
03/21/18 10:04 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The P three has a rev limiter. I think it’s only available in the point type. I’ve got one in my Charger. I have not hit the rev limiter yet. 😳
Re: Pertronix distributor with Eddy heads? [Re: 64Post] #2470345
03/22/18 01:13 PM
03/22/18 01:13 PM
busboy Offline OP
busboy  Offline OP
Thanks 64Post, were you eventually able to get everything to fit?
Re: Pertronix distributor with Eddy heads? [Re: busboy] #2470755
03/23/18 12:15 AM
03/23/18 12:15 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yes.
