5.7 Identification #2468707
03/19/18 07:04 PM
03/19/18 07:04 PM
ct.
moparlouie Offline OP
ct.
I just picked up a New Crate 5.7 Hemi. I ran the full part# to try and find out its application (s) But no luck on the (whole#) It is P53022755JA without the P & JA it has shown Dodge Ram. There is also another # TNXE6044810415. Can anyone tell me more on the application of this 5.7? Thanks
Have been a member for years!
Re: 5.7 Identification [Re: moparlouie] #2468725
03/19/18 07:36 PM
03/19/18 07:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
based on the coils it is 06+
based on the timing cover 08-
bout the only other thing is weather or not its mds, are there plugs or solenoids in the holes in the valley?
Re: 5.7 Identification [Re: moparlouie] #2468967
03/20/18 09:28 AM
03/20/18 09:28 AM
Bowling Green, KY
BlakDak71 Offline
BlakDak71  Offline
Bowling Green, KY
Got a picture of the entire engine? Truck vs car has a different intake and timing cover.
Re: 5.7 Identification [Re: moparlouie] #2469101
03/20/18 01:27 PM
03/20/18 01:27 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I see the dip stick on the left, my 06 magnum is on the right... so I'd guess truck, not sure were jeeps are located.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 5.7 Identification [Re: moparlouie] #2469206
03/20/18 04:03 PM
03/20/18 04:03 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
09-up truck 5.7
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 5.7 Identification [Re: moparlouie] #2469434
03/20/18 11:10 PM
03/20/18 11:10 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Look at the base of the block just above the oil pan, flat milled section.
should start with a number then 2 letters then 5.7.
1st # = year
1st letter= month
2nd letter=day followed by 5.7
This is what i got from my research and it's accurate for the 2003 to 2008.
Matt
Re: 5.7 Identification [Re: moparlouie] #2469843
03/21/18 06:08 PM
03/21/18 06:08 PM
ct.
ct.
Thank you all, was told it was an 07-09, and I do believe a truck, 395 HP version. Yelladustr, are you sure. I just couldn't find it for certain and when I sell it I need to know as much as I can? Again, The JA at the end of the part# would not show up in any search. Here is another pic. thank you all.
Re: 5.7 Identification [Re: moparlouie] #2470300
03/22/18 12:01 PM
03/22/18 12:01 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Truck
09+
Re: 5.7 Identification [Re: moparlouie] #2471064
03/23/18 07:08 PM
03/23/18 07:08 PM
ct.
ct.
Thanks again.
