T&D single shaft rockers 440-1 #2468656
03/19/18 04:51 PM
03/19/18 04:51 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I thought there was a topic on this a while back but I searched and couldn't find it.
T&D 440-1 single shaft rockers.
I need to replace the studs and nuts that hold the T&D rocker shafts to the heads. Is there a part # someone could share with me?
Re: T&D single shaft rockers 440-1 [Re: cl440] #2468686
03/19/18 06:15 PM
03/19/18 06:15 PM
USA
B3RE Offline
B3RE  Offline
USA
Can't help with a part number, but the lengths are 4@ 3.150" and 6@ 2.500". If you call T&D, I'm sure Sheldon would sell you a set.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: T&D single shaft rockers 440-1 [Re: B3RE] #2468956
03/20/18 08:35 AM
03/20/18 08:35 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I emailed him yesterday. I will call him today and order. Didn't know if there was a part# to order from Summit or Jegs or if I had to order direct?
Re: T&D single shaft rockers 440-1 [Re: cl440] #2469058
03/20/18 12:30 PM
03/20/18 12:30 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Called T&D and spoke with Sheldon. Studs and nuts ordered. Thanks
