Trailer Advice - Whats on your wish list?
#2468572
03/19/18 01:48 PM
03/19/18 01:48 PM
Triple Threat
Renton Washington
A buddy and I are looking at ordering new enclosed gooseneck trailers. What are your must haves? If you were making a wish list what would be on it?
We're looking at 42-44' trailers with bathrooms and a bed in the riser area.
Re: Trailer Advice - Whats on your wish list?
[Re: Locomotion]
#2468587
03/19/18 02:33 PM
03/19/18 02:33 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Make sure you read up on the upcoming CDL rule changes. X amount of weight and boy are you on their radar. Going after horse trailers big time
[Re: Triple Threat]
#2468590
03/19/18 02:45 PM
03/19/18 02:45 PM
Posts: 19,358 Las Vegas
Al_Alguire
Las Vegas
Beside the usual things, ac/heat, Gen compartment, 16" tires, etc. The stuff that is generally in every trailer.
These are things I will have in my next trailer the end of this year. LED lighting everywhere(as much 12 volt as possiblwe) to including outside. Wheel well cabinets, a fold down table. TV/Monitor and sound system inside and out. As much cabinetry as you can fit in the trailer, overhead and base cabinets as well as overhead on opposite side of wheelwell cabinet. Storage for things like ratchet straps, portable awnings, chairs, oil etc, I like having a closet to hang my gear, a winch compartment either under cabinet or in floor, and a toolbox under the counter top. Extended rear ramp to ease loading and unloading. Rear loading lights. Plumbed for air outside and inside and room for under cabinet compressor. 35 or 50 amp service for shore power. As large and inverter as I needed. Think that's most of it. Id like to have a good awning that attached to trailer and storage for that too, get tired of the portables.
[Re: Triple Threat]
#2468595
03/19/18 02:52 PM
03/19/18 02:52 PM
Posts: 874 Missouri
jwb123
Missouri
I had a 34 foot tag with living quarters. In part due to the weight and the stories about state patrol, giving tickets for cdl, weight etc. I sold it and got a 26 foot tag, and a crank up slide in camper for the truck to stay in at the races. Believe it or not the rig now weighs 2,000 lbs less, than the 34 trailer. My camper has a queen bed, A/C, furnace bathroom with shower, when it is cranked down its the same height as the trailer, improving fuel mileage. I been averaging 13 mpg, Plus I can take just the camper fishing when I want to. Also most highway patrol see a slide in camper pulling a smaller tag trailer with no decals, might think it has a ranger or other 4 wheeler in it, not a race car. I did buy an extended tongue on the trailer to keep the everything in clearance on tight turns. I always like storage in the floor for spare tires and other stuff. 16 inch tires and a fat man door to get in the car when loading.
[Re: Triple Threat]
#2468695
03/19/18 06:35 PM
03/19/18 06:35 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
besides the stuff already listed, if I ordered a new trailer today, I would 17.5 wheels and tires and a air ride suspension. The air ride would allow me to lower the trailer once I got to the track, make off loading car easier and jumping in and out 100 freaking times a day less of a work out for this old man.
Joe
Without Data, you’re just another guy with an opinion.
[Re: J_BODY]
#2468961
03/20/18 09:05 AM
03/20/18 09:05 AM
Posts: 10,020 MN
JERICOGTX
MN
https://www.racingjunk.com/Trailers-with...p;from=search#4This is our “wish trailer”. It’s also high enough that we could throw the Jeep in it and spend some weekends in the cooler high country in the summer. Also like that it has room in front of the cabinets for the golf cart. Would also be easier to cool the sleeping area. Someday..... Been looking at that exact trailer for over a year now. Layout is perfect for what I'm looking for. Just needs a roof air, heat, and a fridge.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2469048
03/20/18 12:23 PM
03/20/18 12:23 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
Got me an old 28' Haulmark. Just get as big as you can afford. You can always add things as you go. That is what I have been doing. Mine was too good of a deal to pass up. I have repainted the entire inside white, added overhead aluminum cabinets, battery box & winch, electric tongue jack and being that i am in the hood I added latches that i lock from the inside so even if someone snips the padlocks off of the big rear door they still cannot open it from the outside.
I also use the electric tongue jack as a anti-theft device in addition to the tongue lock. Jack it up as high as it will go & pull the fuse which is hidden in the harness. Then no one else can lower it onto their truck to be able to drive away. I also wrap chains thru the wheels & lock them together.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Triple Threat]
#2469059
03/20/18 12:30 PM
03/20/18 12:30 PM
Al_Alguire
Las Vegas
Dustin has a 28'(I think) trailer currently. I can understand wanting more. I waffled between a large living quarters trailer and shorter trailer and motorhome. I ended up with the latter.
Definitely an electric tongue jack, because I'm old and lazy. We lower ours all the way and remove the power to it.
[Re: Triple Threat]
#2469068
03/20/18 12:39 PM
03/20/18 12:39 PM
Posts: 10,020 MN
JERICOGTX
MN
Electric tongue jack is a must have for most enclosed trailers, and really every Gooseneck trailer it should be standard. The LQ trailer vs. Motorhome/Tag combo, is really up to what do you do other then go racing? I also have a 24' open trailer to haul my SkidSteer, so I still need a diesel truck. I'm also thinking long term. When I retire, I want to head south for the winter, and race my way north as the weather gets nice, and enjoy as many tracks as I can. Since it's just me, I don't need a ton of living space.
69 GTX
68 Road Runner
[Re: Al_Alguire]
#2469128
03/20/18 02:19 PM
03/20/18 02:19 PM
Triple Threat
Renton Washington
Dustin has a 28'(I think) trailer currently. I can understand wanting more. Correct, 07 28' Pace currently. I spend about 25 weekends a year at the racetrack (our season is short) so having some more amenities would be nice. Not required, but would be nice. If we can find something at a fair price point we're planning to pull the trigger on two. We've been window shopping the various trailers on RJ like what Jay posted, those are in the realm of what we're after. Currently exploring a few different quotes from a few different sources and manufacturers, some which think the trailers are made of gold, rather than steel. Aluminum isn't in the budget so ATC, Intech, T&E and Goldrush are off the table. A personal favorite of mine: https://www.racingjunk.com/Trailers-with...from=category#2
[Re: 340Cuda]
#2469131
03/20/18 02:25 PM
03/20/18 02:25 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I ordered and picked up my trailer last year but it’s a lot smaller than the one you are looking for (26 footer). I had it wire for a stereo with four speakers and out side antenna. Then I wired in my stereo. I had a mouse hole installed for a winch and put mine in. Garment closet worked out very nice because a 30 gallon fuel barrofits perfect with lots of extra room. Inside light and extra electrical outlets. One electrical outlet up front outside. Two quarts 500 watt lights which I later bought led lights for. Rubber coin floor then I mounted diamond plates where the tires sit. 16 inch wheels and tires. Smooth side no rivets. 4 foot side door. Workbench and I wired in an inverter.
