They ever make a 72 Dodge Ramcharger(found out its a 78) #2468022
03/18/18 10:50 AM
03/18/18 10:50 AM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Was it ever produced? I know they produced them from 74 to 93 but wondering if there was a production or limited production or some sort of production or start in 72? is there a 73 Ram charger also?
Thnks,
Wizard
Guns, God, and Country. U.S. Veteran
Re: Did they ever make a 72 Dodge Ramcharger [Re: Wizard] #2468034
03/18/18 11:13 AM
03/18/18 11:13 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
No , nothing before 74 model year , there was a pre release run of 3 or 4 trucks in early 74 model year , (Sep of 73) they had a bed wall between the passenger compartment and the bed area and the cut door frames like the 74's
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Did they ever make a 72 Dodge Ramcharger [Re: ric3xrt] #2468046
03/18/18 11:37 AM
03/18/18 11:37 AM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Well, I found a truck with a marker light that says 72 on it. What is this then?
Re: Did they ever make a 72 Dodge Ramcharger [Re: Wizard] #2468053
03/18/18 11:51 AM
03/18/18 11:51 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
The marker lamp date means nothing. Couldve been swapped , or maybe they ran so many in 72 that they were still using those containers many years later.Trucks ran those markers through 80, a body through 76. Many others as well. Mopar was planning on using a bunch.
Re: Did they ever make a 72 Dodge Ramcharger [Re: bbtrux] #2468059
03/18/18 12:03 PM
03/18/18 12:03 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Yeah, that's what I am thinking swapped marker light. Here is pic of VIN what does it decode to then?
Re: Did they ever make a 72 Dodge Ramcharger [Re: Wizard] #2468072
03/18/18 12:34 PM
03/18/18 12:34 PM
Canada
demon Offline
demon  Offline
Canada
A glance at the interior tells you it's a 78 or 79.
Late dash. Push button vent window. Floor mount gas pedal. Only 2 years for that combo
The hood and latch indicate 1978.
It's a 78
The number on the lense means nothing other than the year that part went into production.
Example: A 1993 truck could have a 1972 date on the side marker, since that part was used for 21 years on many Chrysler products.
Re: Did they ever make a 72 Dodge Ramcharger [Re: Wizard] #2468101
03/18/18 02:09 PM
03/18/18 02:09 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
78 Slant 6 Ramcharger
Re: Did they ever make a 72 Dodge Ramcharger ( Its a 78 ) [Re: demon] #2468145
03/18/18 04:09 PM
03/18/18 04:09 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Yes, plus I got that marker light off the other side of the truck that doesn't say ram charger. Maybe different fender from a 72 truck went on it at some time. You think its worth saving? Rough but yes its a slant six and motor and trans is in it so is differential. Was last inspected and on the road in 1999. Worth it? Easy to get parts? I can fix and do bodywork and most anything.
