727 for SS hemi
#2467661
03/17/18 10:31 AM
03/17/18 10:31 AM
Posts: 126 kentucky
kyhemi-dart
kentucky
I’m looking at a trans for my SS Hemi dart that should be in the 900 HP range. I’ve listed the details of the trans. Does this sound like a solid set up for what I’ve got? Anything you would change?
“billet input shaft & hub,alum drum,billet servo's,a&a 5 pinion planetary,a&a rear bearing support,a&a reverse pattern valuebody,a&a sprag,wide front band,all roller bearing transmission, spare case, carbon shield”
The current owner has ran it behind a stout hemi and wedge but his car also weighs 2-300# less than ours. Just looking for input, not a trans guy. Thanks
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2467675
03/17/18 11:21 AM
03/17/18 11:21 AM
Posts: 2,902 A shed in England
Tig
A shed in England
Over 800ft/lb ? I would go for a heavy duty/billet O/P shaft as well.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2467677
03/17/18 11:27 AM
03/17/18 11:27 AM
Posts: 9,791 MI, usa
dvw
MI, usa
Mine runs 9.0-9.1@3350lbs. Just took it apart for inspection. Trans itself has over 600 passes. Currently at 350 passes. The only new parts this go round were a stator support, 2 rings and a filter. What parts are stock; case,pump,input & output shafts,3 pin planet carriers,and servos. Frictions and bands still look nearly new. What parts are modified; lightened sun shell,aluminum drums, aluminum rear clutch carrier, A&A super sprag, torington bearings. I would definitely run the steel front planet carrier if using a brake. I have damaged a stock one, but only one (no trans brake). Current stock piece working fine. If you run a sleeved aluminum front drum I would try Teflon rings on the stator support. Mine is not sleeved so steel rings must be run. The check-up revealed a damage stator support in the rear ring groove along with a ring that was half thickness. Red solid band, 5 thin smooth Alto frictions/Kolene steels in the high clutch. 15 springs set at .075". Rear frictions and steels are stock parts, 3.8 lever, early servo with inner and outer springs. It runs a old Turbo action rev manual valve body. We also run stock input/outputs in Dizusters turbo car with a brake. Close to 850hp@3750lbs on radials. It has broke a aftermarket drive shaft, pinion shaft in the rear axle, but never a trans part outside of stripping a stock front planet. You can build a reliable unit yourself. Doug
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2467683
03/17/18 11:50 AM
03/17/18 11:50 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
900HP with a 727. Good Luck!
Hell Hath No Fury Like Mine
Re: 727 for SS hemi
[Re: sixpacksteve]
#2467692
03/17/18 12:11 PM
03/17/18 12:11 PM
dvw
MI, usa
900HP with a 727. Good Luck! Mines pretty close to 900. Have you broke one at this level? If so what part? By building my own I have paid attention to clearances, wear, and failures. Then adjust as necessary. It gets an easy 100 passes a year, not just the occasional blast. Going on year 6. Every automatic car I've raced since the 80's has had a 727. Only hard part failures I've ever had are a stripped front planet, worn aluminum clutch carrier, reaction shaft worn. Doug
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2467751
03/17/18 03:01 PM
03/17/18 03:01 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
Grew up on route 222 in Glendale, many moons ago
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2467760
03/17/18 03:26 PM
03/17/18 03:26 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the VB isn't LBA, I'd definitely upgrade to one.
Re: 727 for SS hemi
[Re: kyhemi-dart]
#2467770
03/17/18 04:10 PM
03/17/18 04:10 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you want top shelf stuff, you're going to spend 7-8K plus the converter. Less if you just want something to function and live. Either way, if I didn't know my way around one, I would talk to one of the shops that do them everyday. You can throw some good parts in one, get it put together pretty close and do OK for most applications, but you're in a little bit different situation depending on how up-to-date your combination is.
Re: 727 for SS hemi
[Re: dvw]
#2467888
03/17/18 10:34 PM
03/17/18 10:34 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
Doug, i glad you had great luck. i've been thru aleast a dozen 727 trans, i have 200 less HP and a coan trans now. has been rebuilt several times. I personally believe if you go more than 600+hp 727 Not the way. Im happy for the guys that have been.
Re: 727 for SS hemi
[Re: sixpacksteve]
#2467895
03/17/18 10:48 PM
03/17/18 10:48 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
900HP with a 727. Good Luck! 1100 hp in a 3700lb car for me. A&A built 727 with a Dynamic converter. Had $5200 into trans/ converter. Had two failures. one transbrake solenoid, and broke a tailshaft housing when a rear end broke. Very trouble free considering the power and weight. Guessing around 200 passes before selling the car.
