Cooling line size with Radiator mounted remote water pump?
#2467389
03/16/18 04:40 PM
03/16/18 04:40 PM
Posts: 625 Indianapolis In. usa
Quickrunner
I have a motor plate for gen3 hemi that's machined with one #12 ORB size outlet/return and two #10 sized inlets. Getting ready to have a custom radiator made with Meziere WP362 mounted to it. The pump has 2 outlets -16 AN O ring threaded. So there will be some step up or down in size to the flare adaptors. So couple questions what would be recommended minimum hose sizes for the 2 inlets and the one return hose? Would -12 hose be big enough for the two inlet hoses from pump to motor? And for the top hose the return hose the -12 ORB adapted to -16 hose for the return to radiator?
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Cooling line size with Radiator mounted remote water pump?
[Re: Quickrunner]
#2467402
03/16/18 04:53 PM
03/16/18 04:53 PM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
I ran -12 hoses all around on 1050-1300+ HP. Never an issues with cooling at all. The S/St car used two -12 with a single -16 return, although at the time we have to make that adapter as no one had one available back then. The other cars use -12 on each side, x2
[Re: Al_Alguire]
#2467417
03/16/18 05:20 PM
03/16/18 05:20 PM
Posts: 4,540 Motor City
6PKRTSE
Motor City
I went with -20 An fittings on my radiator only because my car even though almost 1000 H.P. on Motor is still street driven. But my Mezeire water pump is within the aluminum housing & not mounted to the rad like you are doing.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Quickrunner]
#2467517
03/16/18 09:57 PM
03/16/18 09:57 PM
Al_Alguire
Las Vegas
Don't have many pics here in DC but here is the Predator The Cuda and cant se much but the fitting we welded up to go from a single -16 to 2 -12's And the 99Hemi in the other Cuda
[Re: Quickrunner]
#2468087
03/18/18 01:26 PM
03/18/18 01:26 PM
Quickrunner
What brand do you guys prefer for hose, fitting, and adaptors? Want to use the same brand on the entire car for fuel , coolant, trans etc.... Want to use all black on this build. I hear the Teflon lined is the way to go now but hear some brands are better and more flexible. What is best and who is best source?
[Re: Quickrunner]
#2468118
03/18/18 02:53 PM
03/18/18 02:53 PM
Al_Alguire
Las Vegas
I have used Earls for years it is all on my Stratus, fuel, cooling, dry sump and trans. The dragster we switched to Fragola and have been happy with it as well. Also after the fire in the Barracuda I used all XRP stuff as a local shop sells it and was happy with it as well. Stay away from the Jeg's and Summit house brand stuff IMO. We have had some customers supply it for their builds and IMO it is not as good of a product. We usually always have a fitting or two that has an issue.
[Re: Quickrunner]
#2469632
03/21/18 11:55 AM
03/21/18 11:55 AM
Quickrunner
Yes, I have had some bad experience with Jeg/summit brand fittings. I see XRP & Fragola have a nice catalog on line, the Earls is not very well laid out.
I have decided to use weld on bungs on the motorplate and go with a -20 return after talking with my radiator builder. And -16 for the 2 block feeds from the Meziere pump as it is already -16 ORB outlets. I really didn't want to sacrifice any flow capability with the spallish -10 & -12 thread size my motorplate came with
[Re: Quickrunner]
#2470056
03/21/18 10:28 PM
03/21/18 10:28 PM
6PKRTSE
Motor City
Almost all of mine are Fragola. They are the best as a Company and quality. Everyone doesn't all make the same configurations so I do have a few other XRP and Earls fittings mixed in where needed.
