Re: Can someone tell what this cam is????
[Re: DemonDust]
#246685
03/08/09 05:13 AM
03/08/09 05:13 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
intake lobe is 4254 that is a lobe rated at 288 @.050 with a .440 lobe lift. exhaust is a 1494 lobe rated at 304 @.050 with a .440 lobe lift also.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: gremlinsteve]
#246686
03/08/09 09:11 AM
03/08/09 09:11 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
As Steve says and it looks like a 112 Lobe seperation angle.
RIP Monte Smith
[Re: DemonDust]
#246687
03/08/09 09:45 AM
03/08/09 09:45 AM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
What is it for?
Sorry its for a big block
[Re: gremlinsteve]
#246688
03/08/09 09:47 AM
03/08/09 09:47 AM
Posts: 846 Illinois
moparmattkos
mopar addict
mopar addict
Illinois
steve
So what would total lift be?
[Re: moparmattkos]
#246690
03/08/09 10:26 AM
03/08/09 10:26 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
gross lift would be .660 with a 1.5 and .704 with a 1.6
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: moparmattkos]
#246693
03/08/09 12:59 PM
03/08/09 12:59 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
I have never had a roller cam before, can i install this on a 110 center line???
Not to be a smarta$$ but make sure you get a bronze drive gear for the intermediate shaft, roller springs and lifters, then you'll need different length pushrods as well. Then you'll need to clay the pistons to check for proper clearance.
[Re: moparmattkos]
#246694
03/08/09 01:53 PM
03/08/09 01:53 PM
CompWedgeEngines
Syracuse,NY
The IC is all based on the spec of the car and combo. You'd most likely be fine at 110, but I am also guessing the cam has 4* advance ground into it. The bottom line is put it where you want it, dont get caught up in anything else other than what IC YOU want. The 4* advance usually gets people all confused. SImply put the cam where you needit to be.
RIP Monte Smith
