Re: is an air filter benefical for air flow around the carb?
[Re: DGS]
#2466789
03/15/18 08:50 AM
03/15/18 08:50 AM
Posts: 289 Lowes
steve660
Lowes
I had a 440 running low 12 - hi 11s with a GM dual snorkel breather with 4" alum dryer ducting running to both sides of radiator support. I raced without a filter. Put in a K & N 3 x 14 filter and picked up .10 in the quarter mile.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: DGS]
#2466791
03/15/18 08:54 AM
03/15/18 08:54 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
An air filter can make a difference, but is must not be restrictive, either. The air cleaner base plate design plays an important roll, too, as far as smoothing air flow into carb. There is a reason why so many raise up and then roll down to the air filter lip.
[image][/image]
[Re: DGS]
#2466793
03/15/18 09:00 AM
03/15/18 09:00 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
+1 on not being restrictive. I picked up 0.07-.1 going from a K&N 14x3 element to a WIX racing element, but lost ET when I pulled it off all together.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: DGS]
#2466808
03/15/18 10:24 AM
03/15/18 10:24 AM
Posts: 13,345 Marion, South Carolina [><]
an8sec70cuda
FWIW...Patrick at Pro Systems Carbs once told me that if the car went faster w/ an air filter on it, then the mixture isn't right.
Now IMO, an air filter can help if you have a hood scoop setup that is creating a lot of turbulence at the carb inlet. Doesn't mean the filter made it faster (like K&N claims), it just proved you need to rethink your hood scoop setup.
[Re: DGS]
#2466817
03/15/18 10:45 AM
03/15/18 10:45 AM
Posts: 636 Graz, Austria
DGS
Graz, Austria
instead of using an air filter to reduce turbulence a honeycomb should do the same job while being less restrictive.
[Re: racerx]
#2467322
03/16/18 01:50 PM
03/16/18 01:50 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Kind of remembering Thumpman did a deal were he drill hole in the back of his hood, to stop some of the turbulence under his sixpack hood, I think he said it pick up . Yes it did and the afr's smoothed way out as well..........As for K&N filters, done w'those and only run Wix Racing filters w/damn near zero restriction...........
[Re: Thumperdart]
#2467380
03/16/18 04:07 PM
03/16/18 04:07 PM
BradH
Kind of remembering Thumpman did a deal were he drill hole in the back of his hood, to stop some of the turbulence under his sixpack hood, I think he said it pick up . Yes it did and the afr's smoothed way out as well..........As for K&N filters, done w'those and only run Wix Racing filters w/damn near zero restriction........... I won't drill holes in the back of my scoop, but you did just give me an idea for a spring-loaded pressure bypass in the plate that seals my carb to my hood.
[Re: BradH]
#2467482
03/16/18 08:16 PM
03/16/18 08:16 PM
Posts: 4,064 Mo.
racerx
Mo.
Kind of remembering Thumpman did a deal were he drill hole in the back of his hood, to stop some of the turbulence under his sixpack hood, I think he said it pick up . Yes it did and the afr's smoothed way out as well..........As for K&N filters, done w'those and only run Wix Racing filters w/damn near zero restriction........... I won't drill holes in the back of my scoop, but you did just give me an idea for a spring-loaded pressure bypass in the plate that seals my carb to my hood. But will it smooth out the air flow above the carb ?
[Re: DGS]
#2467485
03/16/18 08:23 PM
03/16/18 08:23 PM
Posts: 4,457 Washington
madscientist
Washington
I worked on a friends FED (nick name balls cooker...long story) and it two 2.250 holes in the back of the scoop to make it run. Before that it was pissed off. I don't remember who it was that told me to drill the holes but it went from untunable to tunable.
[Re: DGS]
#2467493
03/16/18 08:54 PM
03/16/18 08:54 PM
Posts: 11,480 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I always ran a K&N Stubstack with the carb sealed to the scoop. On the last deal we ran, we paid attention to the shape of the pan in the scoop and used a K&N tall velocity stack style air cleaner without oil. Just trying to straighten up any turbulence and keep the big stuff out and it made a difference in how the cylinders looked after a year. Never tried A-B-A tests. Ran good MPH and seemed happy.
[Re: madscientist]
#2467602
03/17/18 02:20 AM
03/17/18 02:20 AM
Posts: 2,070 CA
crackedback
CA
I worked on a friends FED (nick name balls cooker...long story) and it two 2.250 holes in the back of the scoop to make it run. Before that it was pissed off. I don't remember who it was that told me to drill the holes but it went from untunable to tunable. We called that "air packing" which basically creates a blockwall of high pressure in the scoop/opening. Drill holes, pressure is released and flow is re-established. A good filter is beneficial on a drop base. Not so much in a velocity stack, etc. Carbs like air coming in from STRAIGHT down, not turning corners to enter the venturis. There are test out there that display this.
[Re: crackedback]
#2467611
03/17/18 02:44 AM
03/17/18 02:44 AM
Posts: 43,095 Bend,OR USA
Cab_Burge
One of the last drag race motors I dyno tune in SO CA was a 440 block stroke to 3.91 stroke with a set of CNC ported B1-BS heads taken out to M.W. intake port size, they flowed right at 350 CFM at .700 on the intakes. The motor had a little over 12.0 to 1 compression and a M.W. port size tunnel ram with a pair of Holley 750 D.P. prepared by JET performance in SO CA and a old Crane custom ground solid roller cam, nothing all out race at all We played with timing, valve lash, spark plug gap and heat range and finally treid a set of nine inch tall velocity stacks with a set of 11 inch diameter by three inch tall paper air filter elements on top of the stacks, George, the dyno operator, said that change will make the motor lose HP, it didn't It gained around 8 HP from the bottom RPM all the way up to the peak RPM, 7000 RPM I'm a firm believer on all Holley D.P. that straightening the air flow up above those carbs. really help them run better
