Fuel pump recommendations for a 500hp '71 440?
#2466698
03/15/18 12:08 AM
03/15/18 12:08 AM
Posts: 1,185 Nanaimo, BC
NOrrTH
Nanaimo, BC
Engine wont fire after sitting a couple/few weeks without dumping gas down the carb. I don't think its the new Edlebrock 800 cfm accelerator pump. Its still running the oem fuel pump and I've done heads, cam, intake, etc. Been told I should think about upgrading it.
Can anyone recommend a good replacement for it?
Thank you.
'71 GTX N96 auto 3:55
'74 Challenger 440+6 4spd 4:10
'71 Duster 340 auto 4:10
Re: Fuel pump recommendations for a 500hp '71 440?
[Re: NOrrTH]
#2466812
03/15/18 10:29 AM
03/15/18 10:29 AM
Posts: 13,356 Marion, South Carolina [><]
an8sec70cuda
I've used the Carter race pump on a few builds w/ no regulator...no problems.
[Re: NOrrTH]
#2467153
03/16/18 12:07 AM
03/16/18 12:07 AM
Posts: 10,200 Someplace you aren't
SomeCarGuy
Edelbrock makes a good mechanical pump. I can tell you for a fact it won’t solve the dry bowl issue. After three days I still need to pour gas down the carb. Before then it’s golden.
I want my fair share
[Re: NOrrTH]
#2467270
03/16/18 11:46 AM
03/16/18 11:46 AM
SomeCarGuy
You need to add an electric if you want to stop the problem you are having. You need one that will let fuel go through when offunless you want to ditch the mechanical altogether. Just running an electric for a few seconds will fill the bowls when dry
[Re: NOrrTH]
#2467287
03/16/18 12:30 PM
03/16/18 12:30 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I've run the Carter but with a Holley red pump, I'm going with a Quick Fuel electronic pump now.
Have a great day Iowan
"obsolete is neat"
[Re: ahy]
#2467829
03/17/18 07:23 PM
03/17/18 07:23 PM
Posts: 4,669 Wichita
GY3
Wichita
Carter Street/Strip pump from Mancini Racing.
