Re: new turn signal switch
[Re: 76orangewagon]
#2466620
03/14/18 10:02 PM
03/14/18 10:02 PM
Posts: 4,179 California
mickm
California
I recently picked up all the NOS parts for my E body column from eBay. It's a nice idea, but not in my price range at the moment.
[Re: fastmark]
#2466649
03/14/18 10:54 PM
03/14/18 10:54 PM
mickm
California
My last customer bought a repop on eBay for about 40 bucks. It works fine. You do have to file down the hazard flasher pull. A 70 column has the narrow slot and the repops are wider like later years. I guess you could enlarge the slot in the column but I modified the switch. That's pretty much what I figured. Thanks for the input...
[Re: mickm]
#2466716
03/15/18 12:54 AM
03/15/18 12:54 AM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
My last customer bought a repop on eBay for about 40 bucks. It works fine. You do have to file down the hazard flasher pull. A 70 column has the narrow slot and the repops are wider like later years. I guess you could enlarge the slot in the column but I modified the switch. That's pretty much what I figured. Thanks for the input... I think there is somebody doing the 70 turn signal now. If I find it I will pm you
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: HEMICUDA]
#2467228
03/16/18 07:58 AM
03/16/18 07:58 AM
Posts: 403 Pittsburgh, PA
Slotts
Pittsburgh, PA
Thank you! Mickey, I replied to your email. That's why you get all my work.
Thank you, Mike! BTW, your order is finished for the 78 AMC Pacer Station Wagon you are working on... Opps! Did I let the cat out of the bag??? Jim
[Re: Slotts]
#2467291
03/16/18 12:36 PM
03/16/18 12:36 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Thank you, Mike! BTW, your order is finished for the 78 AMC Pacer Station Wagon you are working on... Opps! Did I let the cat out of the bag??? Jim You got that right Jim, I can get x50 or more of those compared to x1 70 Cuda for the same money.
