69 Dart ignition key light install question #2466402
03/14/18 03:06 PM
03/14/18 03:06 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am reassembling my 69 Dart dashboard and just reinstalled the main wiring harness. While doing so, I wanted to add an auxiliary light harness. All of the various facets of the auxiliary harness fall into place with the exception of the ignition key light. I pulled the auxiliary light harness I have off of a 1968 Dart dash harness so I assumed all would be the same when adding it to a 69 harness. However, the thin metal bezel that the light is attached to won't fit over the ignition switch. The ignition switch is about 1 1/8" in diameter and the hole in the bezel is just under an inch. Were 1968 ignition switches smaller in diameter than 69? The 68 dash harness I took the aux. harness from did not have the ignition switch with it so I can't compare it to my 69 switch. I would think they would have been the same.
Re: 69 Dart ignition key light install question [Re: 440mopar] #2466720
03/15/18 01:00 AM
03/15/18 01:00 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Anyone?
Re: 69 Dart ignition key light install question [Re: 440mopar] #2466918
03/15/18 02:59 PM
03/15/18 02:59 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The '69 Dart ignition switch is larger than a '68.
Re: 69 Dart ignition key light install question [Re: GODSCOUNTRY340] #2467099
03/15/18 09:59 PM
03/15/18 09:59 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Anyone have a picture of a 68?
Abe Lincoln
Re: 69 Dart ignition key light install question [Re: dart4forte] #2467133
03/15/18 11:16 PM
03/15/18 11:16 PM
'68, a good bit smaller.
Re: 69 Dart ignition key light install question [Re: GODSCOUNTRY340] #2467167
03/16/18 12:33 AM
03/16/18 12:33 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Thanks for the info. and picture. I guess I will have to look for a 69 key light and bezel.
