WHO CONVERTS AMP GAUGES TO VOLTS? #2466292
03/14/18 11:46 AM
03/14/18 11:46 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I remember seeing this a looooong time ago, that someone actually converted one for a late B body, and I'm sure others as well. Anyone know who does this?
Thanks in advance
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: WHO CONVERTS AMP GAUGES TO VOLTS? [Re: Magnumguy] #2466307
03/14/18 12:16 PM
03/14/18 12:16 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Mopar Action did a how to on a 71 B body once. You had to look hard to tell the difference.
Re: WHO CONVERTS AMP GAUGES TO VOLTS? [Re: Magnumguy] #2466438
03/14/18 03:59 PM
03/14/18 03:59 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
welll I'm pro ammeter gauge guy... When you undertand how it works, what it means on how to keep safe your charging network, won't get worried anyore about the ammeter ghost fears
but, if you want... on a quick search, found this:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/783474/voltmeter-mod-for-mopars.html
I haven't read it really, but on a quick overview checked they mention about the sunpro voltimeter gauge which uses to be the one used on the conversion
Re: WHO CONVERTS AMP GAUGES TO VOLTS? [Re: Magnumguy] #2466449
03/14/18 04:10 PM
03/14/18 04:10 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
aside that, well your late B body is a shunted charging system so you have less to worry about the ammeter ghostes and fears LOL
another thread
https://www.forbbodiesonly.com/moparforum/threads/amp-meter-to-volt-meter-conversion.40423/
This are replacing the full load ammeters, where the hosuing and PCB are diff from the shunted kind. on the shunted kind will need to isolate from PCB ( if pressent ) and not just the housing
Re: WHO CONVERTS AMP GAUGES TO VOLTS? [Re: Magnumguy] #2466670
03/14/18 11:36 PM
03/14/18 11:36 PM
S.E.Ohio
S.E.Ohio
The one I saw had even changed the face of the gauge to indicate volts vs amps.
Re: WHO CONVERTS AMP GAUGES TO VOLTS? [Re: Magnumguy] #2466743
03/15/18 02:06 AM
03/15/18 02:06 AM
Alberta Canada
PossessedDuster Offline
Alberta Canada
I had the one in my Duster's rallye gauge cluster done by redline
https://redlinegaugeworks.com/
Re: WHO CONVERTS AMP GAUGES TO VOLTS? [Re: Magnumguy] #2466798
03/15/18 09:36 AM
03/15/18 09:36 AM
Pennsylvania, Chester County
RonLiv Offline
RonLiv  Offline
There is a guy in South Carolina "TachMan" I think will do it. http://Tachman.com
Re: WHO CONVERTS AMP GAUGES TO VOLTS? [Re: Magnumguy] #2466803
03/15/18 10:01 AM
03/15/18 10:01 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I had a company do one for me. I think it’s called Instrument Specialties. They don’t change the face to volts thought. Did the complete gauge set for 70 RR.
