Re: Suggestions needed for 2nd Gen HEMI intake.
[Re: DoubleD]
#2466886
03/15/18 01:32 PM
03/15/18 01:32 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
Compression is just at 13-1 with victor jr. heads - I will be running C-12 to be safe its in a 64 dodge NSS. its screaming for bigger carbs - I have a solution for that - but that will be down the road a little Nice piece. My 528" as pictured above made slightly more than that with only 10.5:1 on 93 pump gas since I still street drive all of my cars. Yep, I knew mine was going to want more for carbs which is why I went with the tunnel ram and two 1050's.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Uncle Barry]
#2468530
03/19/18 12:00 PM
03/19/18 12:00 PM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
Good. Now we need someone (maybe AndyF) to chime in as to which of those 2 would make more power. I have not run the Stage V. I hate say anything good about Indy but I couldn't believe it when we took off a $3,500 Ray Barton intake and put on a Mod Man and only lost 3 hundreths. Which Barton intake? I'm only asking because I'm running a modman and it works great for what I do but I figured one of his single planes would really wake my combo up. Had to be a crossram. The only thing the big Barton or Indy single 4500 intakes won't outrun is a good tunnelram.
[Re: GTSDave]
#2469088
03/20/18 01:04 PM
03/20/18 01:04 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
RICKSEEMAN, That Barton intake is a very nice looking intake! I found one of the INDY Cross Rams and a very fair price, and ordered it in this week. It should work well for what I am trying. If not, then I will look at other options.
Thanks for all the advice!
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: GTSDave]
#2469113
03/20/18 01:52 PM
03/20/18 01:52 PM
GTSDave
DoubleD, you are correct.
The deck is milled. I can't run the sheet metal intakes in NSS. The plan is to work the intake to fit. My deck height is 10.40.
-Dave
[Re: 72Challenger]
#2469122
03/20/18 02:12 PM
03/20/18 02:12 PM
GTSDave
Tunnel rams are not allowed in the NSS classes I run in. I have the bottom of one of those manifolds, but not the carb section. Even if I did, I couldn't use it. Wish we could.... How would this work out, an old Weiand 2x4 dommie carb setup?
