are all 71-74 charger tail light housing the same??? #2466121
03/13/18 11:46 PM
03/13/18 11:46 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
I was wondering if all 71-74 charger tail light housing the same? if not what is the difference in each year if any besides part numbers...
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466144
03/14/18 12:31 AM
03/14/18 12:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
No, each lenses kind/setup get its own housing! All interchanges between any year of bumper but as full asembly thought
Some diff numbers can be related just to diff finish, like 72 or 73/74 SEs againts standards of its same years where SEs got chromed accents, and 71 RT-500 with 72 Rallye which are the same just louvers painted black on 72. On these both examples, assembly parts interchange even with diff PNs
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466166
03/14/18 01:16 AM
03/14/18 01:16 AM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
If I have 71 charger r/t tail lights and bezels and need housing it must be 71 or 72 housings?
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466168
03/14/18 01:28 AM
03/14/18 01:28 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Just 71 R/T or 500.... or 72 RALLYE
71 Superbees with body coloured bumpers got also the R/T tailights setup
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466174
03/14/18 01:38 AM
03/14/18 01:38 AM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
I have 71 r/t tail light bezels and lenses only and need housings...what year housings do I need for them to work correctly
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466188
03/14/18 02:22 AM
03/14/18 02:22 AM
Alabama
BigMoneyLewis Offline
Alabama
As mentioned above, You have to have housings from a 71 R/T (or 500) OR 72 Rallye. Those are your only options.
Greg
gregward@mchsi.com phone 256-852-0955
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466209
03/14/18 03:19 AM
03/14/18 03:19 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I can understand my english is not perfect, but still...
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466274
03/14/18 11:09 AM
03/14/18 11:09 AM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
got it thanks
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466293
03/14/18 11:48 AM
03/14/18 11:48 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
The '71 R/T housings are metal and the base/Coupe/SE housings are plastic. The wiring between the two is slightly different with respect to grounding.
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466380
03/14/18 02:30 PM
03/14/18 02:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeah, well, but that doesn't affect... will plug on same trunk plug/body wiring harness, and ground screw into the same location(s) when needed.
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466599
03/14/18 08:52 PM
03/14/18 08:52 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
thanks 71charger, I was not aware that 71's were metal, are the 72 rallyes metal?
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466639
03/14/18 10:36 PM
03/14/18 10:36 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I don't know. I assume they are. It's unlikely they'd re-engineer that part for one model year.
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466648
03/14/18 10:51 PM
03/14/18 10:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeeees... both are the same asssseeeeemblies, just the louvers are "diff" because Rallyes are black finished.
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466680
03/14/18 11:48 PM
03/14/18 11:48 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
thanks Nacho for the info, greatly appreciated
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466962
03/15/18 04:51 PM
03/15/18 04:51 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
This is a plastic housing off of my '71 SE.
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466965
03/15/18 04:58 PM
03/15/18 04:58 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Metal housings from an R/T
Re: are all 71-74 charger tail light housing the same??? [Re: bugsydog] #2466977
03/15/18 05:18 PM
03/15/18 05:18 PM
las vegas, nevada
bugsydog Offline OP
bugsydog  Offline OP
las vegas, nevada
wow, big difference....wanna sell them..lol
