Just picked up a nice set of off the motor 302 heads. Not cast for air injection/smog pump. Each intake runner has a 1/4" deep by 1/4" diameter hole. Can I fill it with Moroso head epoxy? I thought that someone carries a metal rod or square that melts somewhere around 500* and is also a good alternative.
