staggered fan question #2465142
03/12/18 11:46 AM
03/12/18 11:46 AM
moparx Offline OP
moparx  Offline OP
when using duel "staggered" electric fans, does it matter which fan is the high speed unit [inlet or outlet position], or doesn't it matter ? this is for an ac retrofit with aluminum crossflow radiator. thanks in advance as always ! bow
beer
Re: staggered fan question [Re: moparx] #2465143
03/12/18 11:51 AM
03/12/18 11:51 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would think the one closest to the top inlet would be best. But just a personal guess. I seem to recollect the OEM Mopar fans are that way.
Re: staggered fan question [Re: 340Cuda] #2465148
03/12/18 12:01 PM
03/12/18 12:01 PM
moparx Offline OP
moparx  Offline OP
that was my thinking also, but just wanted others opinions.
beer
Re: staggered fan question [Re: moparx] #2465151
03/12/18 12:09 PM
03/12/18 12:09 PM
P
Porter67 Offline
Porter67  Offline
P
Im not up on the highspeed fan part, mine are either on or off?
Re: staggered fan question [Re: moparx] #2465230
03/12/18 03:04 PM
03/12/18 03:04 PM
Chicago
PurpleBeeper Online content
PurpleBeeper  Online Content
Chicago
IMO, that's a tough call. Inlet will be hottest, but you'll probably use the low speed fan more. To make sure you don't overheat when the A/C is on, put the high speed by the inlet as long as the low speed by the outlet is enough for driving in traffic when you don't have the A/C on.....tough call, so I see why you asked.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: staggered fan question [Re: PurpleBeeper] #2465704
03/13/18 12:17 PM
03/13/18 12:17 PM
moparx Offline OP
moparx  Offline OP
ev2, most OEM fans have a high speed function when the ac is on, so i desire to keep this on this project. looking at two fan, factory setups, it seems the high speed fan is at the inlet side of the radiator. if i could fit a single fan in the radiator center, i would. however, with the cooling setup [radiator/condenser] pushed as far forward as the grille allows, i don't have enough room for the fan motor to front pulley relationship with the engine in the stock location to utilize a single fan. i don't like aftermarket fans for a multitude of reasons. so i'm now down to finding a pair of single fan/shroud combos that will work with what room i have to work with.
beeper, i may have to go with two high speed fans. i also thought about a big blade mechanical clutch fan/shroud combo, but i am not sure i can source a smaller water pump pulley with the right offset to allow belt alignment. wiring has been updated, and this is not an unlimited budget deal. the radiator being used is twice the size of the original, so it should be more than adequate for this application, as the original cooled very well with no shroud and a four blade fan.
beer
