Transmission GURUS ?? #2465610
03/13/18 01:53 AM
03/13/18 01:53 AM
Nevada
dezduster Offline OP
Nevada
Quick history on trans. Came from an 84 5.2 4x4, was supposedly "rebuilt" and had been installed and removed due to NOT WORKING. I didn't and don't know the symptoms and was not bright enough to check input endplay or air check before disassembly.
Upon disassembly found incorrect sized bushing in FORWARD clutch input shaft so extreme wobble was peasant at shafts piloted joint and the 3 tab thrust plate and a very thin thrust shim was present. Rear drive train clearance .022.. New clutches throughout, second gear band, seal rings, seals, bushings and all of the thrust bushings are new except the forward #4 four pinion planetary bushing (LOOKS and measures GOOD). The correct per ATSG .063 fiber (#2 fiber thrust washer) between front and rear clutch packs also present and to spec. The selectable pump fiber washer was .084... 4x4 tail shaft housing installed and everything was reinstalled without pump gasket, input end play .142 hanging vertically tail down. Replaced the pump selectable for .104 and at.122 but the .015 gasket is not on the pump yet so that will be.135 with gasket crush when its installed.
Questions
#1 Where should I shim so as to keep seal rings happy, shaft wobble minimal and is there a chart with hard part specifications?
#2 Should I use Red fiber first reverse band WITH or WITHOUT GROOVES? This is in a street R/C that mud drags, hill climbs, truck pulls and weekend wheeling.
#3 A good 727 transmission rebuild book that maybe gives specs?
#4 A spring for governor getting me a 5200 second to third shift? any suggestions?
Re: Transmission GURUS ?? [Re: dezduster] #2465684
03/13/18 11:43 AM
03/13/18 11:43 AM
moparx Offline
moparx  Offline
the carl monroe book on 727's is a good book, plus the ATSG rebuilding guide and a FSM. there are several places one can get springs and governor weights to tailor your shift rpms, but i don't have them in front of me. others will chime in with that info, i'm sure. hope this has been helpful to some extent.
beer
Re: Transmission GURUS ?? [Re: moparx] #2465714
03/13/18 12:34 PM
03/13/18 12:34 PM
Nevada
Nevada
Thank you MOPARX I Called A&A to day. Robert lined me out on my end play issue. The weight of everything hanging vertical in the case is the problem even with tail housing on they say support the shaft. The red low band with groove is the what they suggest for a performance low/rev band. Ill need to get the 5000 rpm governor assembly for up shift to drive at 5200.
Re: Transmission GURUS ?? [Re: dezduster] #2465729
03/13/18 01:01 PM
03/13/18 01:01 PM
moparx Offline
moparx  Offline
A&A was the one place for springs and weights. my old brain just can't remember things any more ! biggrin glad you got your end play sorted out ! i'm no expert by any imagination on 727's, but i have built several over the years, and have installed a ton of valve body shift kits, as well as modifying valve bodies without using kits, having no failures in the process with the one exception of having the low/reverse band strut falling out after assembly. i always refer to the books i mentioned because of my memory problem. hopefully, others with way more knowledge than me will chime in such as cope and kunkle, and others to make sure i don't steer anybody in the wrong direction ! those guys are excellent "proof readers" for my drabble !
beer
