Need to wire in the reverse light switch and neutral switch for a Tremec five speed. The Tremec has separate two prong plugs for these two functions. The FSM for the original A/T says both the reverse and neutral switches function off the one switch at the shifting lever. The center pin is for the neutral switch and the two outside pins are for the reverse lights. How would I wire in the two new pigtails for this? Thanks!
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
