Re: 727 trans vent relocation
[Re: crash520]
#2465127
03/12/18 10:58 AM
03/12/18 10:58 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
https://www.forbbodiesonly.com/moparforum/threads/727-torqueflite-rear-vent-install-question.146442/nice lil discussion with pictures and everything... I use the same "quick connect" discussed in this thread. The trans in my old Mirada was the plastic push in vent and never leaked a drop. My current trans will push fluid out during a pass, thus the catch can was installed. I've also noted the current vent is not in the same location as what the Mirada had. Believe it was the same as the picture noted in the link.
[Re: crash520]
#2465209
03/12/18 02:31 PM
03/12/18 02:31 PM
Posts: 11,521 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Back of the case so that it is open to the cavity under the rear support. I like it at 11 o'clock above the bolt hole on top left as long as there is not a clearance issue. Just below the bolt hole would be my second choice.
[Re: RTSE4ME]
#2465296
03/12/18 05:09 PM
03/12/18 05:09 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
When I built my 904 John Cope told me not to add a rear vent. It was also mentioned in the link Cope no longer vents at the rear. When I added my trans brake I was told if I drilled the piston (I did) instead of the drum I wouldn't need to relocate the vent. Guess what? It blew fluid out the factory vent so the transmission had to come back out and partially apart to move it.
[Re: crash520]
#2465375
03/12/18 07:55 PM
03/12/18 07:55 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Done many, never had one leak where I put them.
[Re: RTSE4ME]
#2465446
03/12/18 09:54 PM
03/12/18 09:54 PM
Posts: 1,557 New Smyrna Beach FL
scottb
New Smyrna Beach FL
When I built my 904 John Cope told me not to add a rear vent. It was also mentioned in the link Cope no longer vents at the rear. That is what Joe at tranz act told me to not to move it to the back
[Re: crash520]
#2467043
03/15/18 07:54 PM
03/15/18 07:54 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Normally the stock vents don't leak, but I never say never. I've never had one leak at the rear and I've taken brakes out and put regular manual units in without plugging it. I wouldn't put a vent in the rear with a governor still in it. BUT If the guys who do it all day, everyday say not to move it, they have a reason and I'm not going to argue with them.
[Re: crash520]
#2467053
03/15/18 08:17 PM
03/15/18 08:17 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
My advice is to be cautious of drilling the case close to the sealing surface. Then be even more careful tightening the tapered pipe fitting with the hole so close to the case edge/ sealing surface.
[Re: CMcAllister]
#2467105
03/15/18 10:09 PM
03/15/18 10:09 PM
dartman366
Mt. Vernon, Ohio
Normally the stock vents don't leak, but I never say never. I've never had one leak at the rear and I've taken brakes out and put regular manual units in without plugging it. I wouldn't put a vent in the rear with a governor still in it. BUT If the guys who do it all day, everyday say not to move it, they have a reason and I'm not going to argue with them. what seems to be the reasoning for not putting the vent in the rear of the case?, for years it was the accepted practice to do just that and now it's appears to be taboo, I have always put the vent in the rear of the case and plugged the front one.
[Re: MR_P_BODY]
#2467114
03/15/18 10:31 PM
03/15/18 10:31 PM
dartman366
Mt. Vernon, Ohio
But you did that with a brake, I never put it the rear if NOT using a brake I thought they ment in any combination, maybe I mis undestood.
[Re: crash520]
#2467123
03/15/18 10:48 PM
03/15/18 10:48 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't know why it went out of fashion. They're saying Cope and Tranzact don't want it done. I don't know the reason. All I know is I've done it for years on units with a brake from Griner and Protrans with no issues. Perhaps they stopped with putting the small hole in the high drum which I understand is the main reason for moving it. I'd like to hear from one of them for a clarification.
[Re: crash520]
#2467139
03/15/18 11:32 PM
03/15/18 11:32 PM
TRENDZ
Milwaukee WI
My last trans was built by A&A. It was the only trans I had with the vent moved to the rear, and the only trans I had that leaked from a vent. I ended up running a nylon tube up to the dipstick to prevent the leak from oiling down the car on a heavy pass. Hardened shafts-so no governor. Just didn't work for my combo. The tube solved the problem so I guess it turned out fine in the end. I could see how a drilled drum would cause an issue with the pump located vent. Maybe they vent the drum differently now so relocation isn't needed?
[Re: CMcAllister]
#2467166
03/16/18 12:32 AM
03/16/18 12:32 AM
Posts: 2,041 MD
RTSE4ME
MD
I don't know why it went out of fashion. They're saying Cope and Tranzact don't want it done. I don't know the reason. All I know is I've done it for years on units with a brake from Griner and Protrans with no issues. Perhaps they stopped with putting the small hole in the high drum which I understand is the main reason for moving it. I'd like to hear from one of them for a clarification. I am not running a brake. When I posted my original response a brake was not mentioned by OP.
[Re: CMcAllister]
#2467528
03/16/18 10:15 PM
03/16/18 10:15 PM
dartman366
Mt. Vernon, Ohio
I run one of Cope's transbrake valve bodys and don't honestly remember John telling me to NOT put the vent in the rear, when I put the new billet steel high gear drum in I drilled the piston which pushes the fluid toward the rear,, with that said I have not had a issue from the rear vent.
[Re: crash520]
#2932704
06/13/21 06:58 AM
06/13/21 06:58 AM
Posts: 1 canada
martiscore
canada
You can also use other materials to ensure that the alloy material is essential in this case. I once put a panel for myself and made a mistake with the materials. So it did not last a year, as it broke and began to rattle. So now I constantly look at what is where. To then know what is better to take products for yourself and your loved ones. Recently, there was a question about the air conditioner and its choice of truth. Who not to ask everyone complains about something? I even started to think about not taking it at all.
