727 band material? #2465004
03/11/18 11:32 PM
03/11/18 11:32 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
It’s been 15 years since I rebuilt my 727 and it’s time for a refresh. What material on the low/reverse band would be good for a 600 horsepower street car?
shruggy
Re: 727 band material? [Re: ccdave] #2465026
03/12/18 12:19 AM
03/12/18 12:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Low reverse can use a stock part. The sprag takes most of the load on a LBA valve body, and all of the load on a non LBA valve body. Used for reverse only. For a K/D band I prefer the red material. Forward clutches use red Alto. Rear clutch works fine with the stock silver clutches.
Doug
Re: 727 band material? [Re: dvw] #2465554
03/12/18 11:58 PM
03/12/18 11:58 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Thanks,
I was just looking through my box of extra parts and came across a front solid band that says “DuPont Kevlar on the material. What are the pros and cons of the red vs Kevlar?
Re: 727 band material? [Re: ccdave] #2465643
03/13/18 07:18 AM
03/13/18 07:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Do NOT use the Kevlar with and aluminum drum. Again on a rear band (as long as it's a steel drum) doesn't matter.
Doug
Re: 727 band material? [Re: ccdave] #2465726
03/13/18 12:52 PM
03/13/18 12:52 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Front drum is steel.
