Stainless drip rail molding #2464654
03/11/18 11:46 AM
03/11/18 11:46 AM
Az
69hemibeep Offline OP
Az
I have a damaged left side one I read to replace on a 69 2dr hdt. Did they make a larger one for vinyl tops?
1969 Hemi Roadrunner 2nd owner
Re: Stainless drip rail molding [Re: 69hemibeep] #2464866
03/11/18 07:08 PM
03/11/18 07:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, it was a little bit bigger to give the vinyl some space.
Re: Stainless drip rail molding [Re: 71birdJ68] #2464913
03/11/18 08:42 PM
03/11/18 08:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I only recall this applying to 71-4 B bodies due to the thicker padded vinyl roof material esp halo tops, I've never had an issue with 68-70 B body or 70-74 E body trim fitting it back to NON vinyl top cars after installing a vinyl top
Re: Stainless drip rail molding [Re: DAYCLONA] #2464930
03/11/18 09:09 PM
03/11/18 09:09 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You may be right, the trim on my 75 A body is loose, and rattles without the vinyl top, so I thought the others were to.
