Harness mounting question
#2464294
03/10/18 02:51 PM
03/10/18 02:51 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
So I’ve got my roll bar in and I’m looking to mount my harness. It’s a V-mount style harness that mounts to the backbrace at a single point. I can’t find anything in the rule book about what’s an acceptable mount type. It just says “securely mounted”. Do I have to weld a tab onto the backbrace, or is it acceptable to drill and bolt the mounting tab directly to the bar?
Feel free to show me how you did it.... Thanks!
Re: Harness mounting question
[Re: StealthWedge67]
#2464297
03/10/18 02:58 PM
03/10/18 02:58 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Either or. If you drill and use a through bolt in the bar, you need to weld a through tube in it for a reinforcement. Typically a piece of 5/8"-.058 CM will work for a 1/2' bolt or something similar for a 7/16".
#2464305
03/10/18 03:22 PM
03/10/18 03:22 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
I take the mounting tabs off the belts and wrap them around the Roll Bar tube (more surface area for the Belt to pull against) Additionally I don't believe "Y" belts are accepted by the IHRA or NHRA
"SFI 16.1 - Shoulder harness: A belt assembly, one strap for each shoulder, intended to restrain movement of the upper torso and shoulder regions. It includes adjustment and mounting hardware. Optional cross strap can be used to hold the shoulder harnesses together and if the cross strap is in front of the driver it must be capable of being released in a single motion. A Y-type shoulder harness, i.e. both shoulder straps become a single strap with one attachment point, is not permitted. (Effective January 1, 2005)"
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: CMcAllister]
#2464309
03/10/18 03:33 PM
03/10/18 03:33 PM
StealthWedge67
Puyallup, WA
Either or. If you drill and use a through bolt in the bar, you need to weld a through tube in it for a reinforcement. Typically a piece of 5/8"-.058 CM will work for a 1/2' bolt or something similar for a 7/16". This is what I was hoping to see.... makes perfect sense. thanks!
[Re: W.I.N. Racing]
#2464313
03/10/18 03:39 PM
03/10/18 03:39 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
These are ok. These are not considered Y type. https://www.summitracing.com/parts/rjs-1126201/overview/
#2464322
03/10/18 03:48 PM
03/10/18 03:48 PM
markz528
Morrow, OH
[Re: markz528]
#2464346
03/10/18 04:51 PM
03/10/18 04:51 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
We used a tab like this on my car and another flat plate also for double shear protection.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: W.I.N. Racing]
#2464370
03/10/18 05:40 PM
03/10/18 05:40 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Additionally I don't believe "Y" belts are accepted by the IHRA or NHRA That would be correct. The V belt is made with one length of material with a mounting tab attached in the middle and it can't come apart to be wrapped. I like the individual harnesses wrapped as well but he was asking about his V assembly.
#2464372
03/10/18 05:43 PM
03/10/18 05:43 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If using a tab, make sure it is mounted in line with the direction of pull.
#2464544
03/11/18 01:26 AM
03/11/18 01:26 AM
StealthWedge67
Puyallup, WA
I’ll be drilling the bar and inserting a sleeve with a through bolt.
Thanks all.
#2464686
03/11/18 12:48 PM
03/11/18 12:48 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I’ll be drilling the bar and inserting a sleeve with a through bolt. That's the way I've always done mine. And as previously mentioned, angle the sleeve so that the direction of pull is inline with the belts. I use grade 8 hardware, too. I don't know if it's a requirement, but I feel better about spending the extra $1.00.
[Re: Dave Hall]
#2464780
03/11/18 03:28 PM
03/11/18 03:28 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The wrap around kind work really well! They don't really slide around because of the slots in the seat. No fab necessary... To be legal, they want some type of a retainer on the bar to keep the belts from sliding out of position. Anything from a couple of muffler clamps to a nice welded D loop will suffice.
[Re: CMcAllister]
#2465060
03/12/18 02:17 AM
03/12/18 02:17 AM
StealthWedge67
Puyallup, WA
The wrap around kind work really well! They don't really slide around because of the slots in the seat. No fab necessary... To be legal, they want some type of a retainer on the bar to keep the belts from sliding out of position. Anything from a couple of muffler clamps to a nice welded D loop will suffice. Car utilizes stock seats, so........
