How much compression is too much?
#2464199
03/10/18 10:12 AM
03/10/18 10:12 AM
Posts: 2,039 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
620ci RB, B1 MC heads, cam is .850" lift solid roller, duration 286/306 @ .050", carbureted on gas. Bore 4.600", stroke 4.665", piston 10.3cc dish volume, combustion chamber volume 52cc, head gasket compressed thickness .066", 4.600 bore size". How much compression ratio would be considered too much? This is a bracket engine, to be raced on a weekly basis. The engine was brought to me with 16.4:1. I can change head gaskets to get it to 15:1 with out doing anything else. The question is, how much is TOO much?
Thanks, Brian
Re: How much compression is too much?
[Re: '72CudaRacer]
#2464239
03/10/18 12:22 PM
03/10/18 12:22 PM
Posts: 4,206 New York
polyspheric
New York
I can change head gaskets to get it to 15:1 with out doing anything else. Losing your quench isn't a good idea unless your VE is very low.
What does your chamber wall look like adjacent to the intake valve?
Boffin Emeritus
[Re: '72CudaRacer]
#2464270
03/10/18 01:44 PM
03/10/18 01:44 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd run the thicker gaskets and not worry about the quench.
[Re: '72CudaRacer]
#2464306
03/10/18 03:23 PM
03/10/18 03:23 PM
Posts: 739 WA
JD Dart
WA
Buddy of mine had the same problem with C/R. He called Koffels and they said the B1 heads don't tolerate much over 15.3. I'd go with the thicker head gasket too. And I must ask what block is that to get 4.600 bore?
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: '72CudaRacer]
#2464308
03/10/18 03:32 PM
03/10/18 03:32 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
No reason for a basic bracket engine to be at that kind of compression ratio for sure. My little B1 was at 15.5 and worked pretty well for what it was. The one from the dragster is 15.3-1 and works pretty well too.
Id like to see the piston that gets you that kind of compression number for sure. I though I saw it was a world block somewhere but maybe not. 4.600 aint gonna leave much room between the cylinders on a 4.800" BS block for sure.
[Re: gregsdart]
#2464319
03/10/18 03:42 PM
03/10/18 03:42 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I'd run the thicker gaskets and not worry about the quench. I have heard that quench effectivness diminishes as rpm goes way up? One of the guys on here did an experiment with a 440 and went from bad quench to tight quench and saw the biggest gains as the RPM went up, big time, like 50 HP. I think it was jesse lackman but don't quote me on that.
[Re: '72CudaRacer]
#2464342
03/10/18 04:38 PM
03/10/18 04:38 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
If it's been working?? Just use it as is... Just dont lug it in some heavy azz turd car and changing the combo to much... Just my 2 cents... Or drag the junk over to Greeneville TN and have the Johnsons dyno it...
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: '72CudaRacer]
#2464344
03/10/18 04:48 PM
03/10/18 04:48 PM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you do consider running methanol, a very sharp engine builder told me 15/1 is about the max that works well. Over that, more fuel is needed to run well, eliminating the advantages, and it is hard on parts.
[Re: fbs63]
#2464377
03/10/18 05:52 PM
03/10/18 05:52 PM
'72CudaRacer
Mooresburg, Tn
What's the lobe separation on the cam? Crane cam, lobe separation 114.
[Re: LSP]
#2464382
03/10/18 05:57 PM
03/10/18 05:57 PM
'72CudaRacer
Mooresburg, Tn
Show a picture of the piston, most aren't finished before installation IMO I can post a picture later tonight, but it is finished. Diamond custom piston, comp height 1.530", intake pocket depth .340" (2.600" titanium valve), exh .390". Piston weighs 654 grams. Not much left to take off of it.
[Re: '72CudaRacer]
#2464402
03/10/18 06:45 PM
03/10/18 06:45 PM
Posts: 30,995 Oregon
AndyF
Thanks, Brian The only way to know if you have too much compression is to test it. Flame travel inside the combustion chamber is very complex. There probably isn't anyone who can read a post on the internet and then tell you if you have too little or too much compression. Even if you had a bunch of pictures of the piston and the combustion chamber I doubt anyone could give you a positive answer. Personally I think that is way too much compression for a bracket engine. The tuning window will be narrow and you'll have to run expensive race fuel. If the car is being raced just for fun then what is the point of the sky high compression ratio?
[Re: AndyF]
#2464453
03/10/18 08:35 PM
03/10/18 08:35 PM
'72CudaRacer
Mooresburg, Tn
Personally I think that is way too much compression for a bracket engine. The tuning window will be narrow and you'll have to run expensive race fuel. If the car is being raced just for fun then what is the point of the sky high compression ratio? [/quote]
This is my line of thinking also Andy. I'm thinking any advantage (IF there is any) to having this much compression is out wayed by the toll that it will take on the engine parts (rings, rods, bearings piston pins, head studs, ect.).
And just so everyone understands, this engine was running when it was brought to me. The last two passes in a 2200lb door car was 5.13 @ 139mph (1/8 mile), even with the problems that I have uncovered. In working through the issues on this engine, I'm hoping to head off as many future issues as I possibly can. I feel like this much compression is just not needed.
Thanks, Brian
[Re: '72CudaRacer]
#2464556
03/11/18 01:51 AM
03/11/18 01:51 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
No real advantage with that much compression, over say around 15.1 comp but if its together as stated you can run it the way it is, just use the correct fuel. Your wider LSA will help with the extra comp. I would just leave it as is and then on next tear down, address the comp issue. Diesels run up to 25.1 ratios, fx high rpm 18000 rpm gas motors run 17.1 comp to assist at that rpm. So you are at Top level comp with your motor. Also, for Just a Bracket motor, you really don't need a 620 ci as well. To me you have a Max built et motor. Send it to me and I will send you a reliable 448 Bracket motor. No Charge.
[Re: sgcuda]
#2464825
03/11/18 05:25 PM
03/11/18 05:25 PM
Sport440
Canton, Ohio
Are you on 4.800" bore centers? That's a lot of compression to seal a head gasket with not a lot of room between bores. The Koleno blocks are on a 4.8 centers, with a 4.60 bore that gives a .200 space center of sealing surface.
[Re: Dave Hall]
#2464901
03/11/18 08:26 PM
03/11/18 08:26 PM
KOS
Run VP Q16 and go haul a$$ with it. my sediments exactly.........just make sure carb is calibrated for it.
[Re: Dave Hall]
#2464904
03/11/18 08:36 PM
03/11/18 08:36 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Run VP Q16 and go haul a$$ with it. It’s one thing to run a heads up program with usually 4 rounds max compared to a bracket program with 7 or more rounds. How much does Q16 cost a gallon again. I think 55 gallons of alcohol was around 165.00 Last year.
