Cheap small block headers....B/E body
#2464167
03/10/18 04:37 AM
03/10/18 04:37 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Looking for some cheap headers for a E body small block that do not go under the steering linkage.....It appears from the pics that the cheap Summits and the Hedman's are nearly identical from the pics and do not go under the steering....Doing a search only found old results from when the cheap headers went under the steering....Any recent experience w the cheap Summits?
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Cheap small block headers....B/E body
[Re: HemiRick]
#2464214
03/10/18 11:10 AM
03/10/18 11:10 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
We ran the Summits on a Charger Fit was decent and they lasted pretty good.Ran them on my plow trucks for like 20 years For a cheap header they cant be beat.They are made by a name brand maker.Rocky
Chrysler Firepower
[Re: HemiRick]
#2464246
03/10/18 12:32 PM
03/10/18 12:32 PM
Posts: 4,765 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Header with ground clearance? The cheapest will be Dougs raw steel. Speedway motors on ebay sells them for $478 free shipping. I used a 10% off online discount at Advance auto.com (10% off but capped at $50 max savings regardless) So with the discount and sales tax I paid $480 for my raw steel D453 headers. They are uncoated but the metal is not Hedman, Hooker-Black Jack crappy thin The Dougs are made from STEEL and not tin.
Keep old mopars alive.
[Re: HemiRick]
#2464249
03/10/18 12:43 PM
03/10/18 12:43 PM
therocks
Niles , Ohio
He asked for cheap.Maybe over 400 is cheap to you but not everyone.Had decent ground clearance on the Charger with Summits.Yeah stering went thur the DS tubes but fit was still good.One set on my plow truck I got 10 years.Not bad for cheap under 100 buck headers that lastedin salty Ohio.The set on my jeep lasted as long also.Rocky
Chrysler Firepower
[Re: HemiRick]
#2464273
03/10/18 01:55 PM
03/10/18 01:55 PM
2boltmain
Holland MI Ottawa
I never said Dougs were cheap. They are not. Theyre expensive. But they are the LEAST expensive of the "great" headers. My suggestion is Summit brand headers, raise the front end as much as PRACTICAL and drive carefully.
[Re: therocks]
#2464287
03/10/18 02:35 PM
03/10/18 02:35 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
He asked for cheap.Maybe over 400 is cheap to you but not everyone.Had decent ground clearance on the Charger with Summits.Yeah stering went thur the DS tubes but fit was still good.One set on my plow truck I got 10 years.Not bad for cheap under 100 buck headers that lastedin salty Ohio.The set on my jeep lasted as long also.Rocky He asked for cheap, but also asked for not going under the steering linkage. On an E-body that combination starts with the Dougs mentioned above. Truck and Jeep headers don't add much to the conversation because even the cheap ones route with plenty of clearance to other components and ground clearance usually isn't an issue. On an E-body with the stance of the two in OPs post, cheap headers will be low to the ground. Unless you drive very careful the drivers side will end up with dents eventually. I've run cheap headman and cheap summit about 10 years apart. Summits were thicker flanged and seemed better built, but with the gap in years headman may have improved theirs too. Look up the installation instructions, Jegs is better about a convienient link than summit. I'd bet money the cheapies still wrap under the center link especially if it lists the same application as fitting a bodies also.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: HemiRick]
#2464293
03/10/18 02:50 PM
03/10/18 02:50 PM
2boltmain
Holland MI Ottawa
I HAVE NEVER understood why the low cost header companies will not offer a header with the TTI/Dougs routing. They have the tooling and equipment. For example- say Walker or Hedman takes their entry level tubing and routes it correctly. Sells those headers for $275-$300 while still offering their traditional pipe smashing design for the current $230.
[Re: 2boltmain]
#2464384
03/10/18 06:04 PM
03/10/18 06:04 PM
Michael Ecks
Columbus, GA
I HAVE NEVER understood why the low cost header companies will not offer a header with the TTI/Dougs routing. They have the tooling and equipment. For example- say Walker or Hedman takes their entry level tubing and routes it correctly. Sells those headers for $275-$300 while still offering their traditional pipe smashing design for the current $230. Easy to answer. 1)The jigs (research and development cost) already exist and people keep buying them as is so why change. 2)The wrap under the center link design was done so that one part fits more vehicles meaning fewer part numbers to try to stock and do production runs on. Its not a matter of a "low cost company" as hooker sells or once sold both smash tube design and better routed super comps.
[Re: HemiRick]
#2464441
03/10/18 07:54 PM
03/10/18 07:54 PM
therocks
Niles , Ohio
I dont know ran a 66 Charger with Summits which were hedmans with 14 inch rims.Never had a problem hitting even on Ohis crappy roads.Oh yeah it was pretty much driven daily at about 30 miles one way.Rocky
Chrysler Firepower
[Re: HemiRick]
#2464572
03/11/18 02:52 AM
03/11/18 02:52 AM
HemiRick
Memphis
I have a set of cheap Blackjack headers I bought 30 yrs ago on another Challenger of mine....small block and do not go under the steering...Maybe I'll steal those..look at the pics of the headers Summit currently sells if the pic is accurate no way the steering goes thru it.....unless all 3 of those tubes go under.....and this much worse than just one.... https://www.summitracing.com/parts/sum-g9040
