Page 9 of 10 1 2 7 8 9 10
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246551
05/02/09 11:31 PM
05/02/09 11:31 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
We tacked the front, side and rear to hold it in place.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246552
05/02/09 11:33 PM
05/02/09 11:33 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
After tacking, I added a few more tacks to hold until I can finish the seam. We also drilled several holes directly over the supports to "fill weld" the pan to the supports.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246553
05/02/09 11:36 PM
05/02/09 11:36 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Then, I welded in the A pillar patch. Yep, it's very hard to weld thin sheetmetal with rust on the back!! But, I was successful.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246554
05/02/09 11:37 PM
05/02/09 11:37 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
So here's where we sit on progress...
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246555
05/02/09 11:39 PM
05/02/09 11:39 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Next week I'll finish up the beads on all sides.
It was nice to see my two sons working on the project!
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246556
05/03/09 11:22 PM
05/03/09 11:22 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Nice job with that cab, it looks great. Your metal work is sweet
Re: My Journey: 1973 Dodge Power Wagon [Re: UCUDANT] #246557
05/04/09 10:19 PM
05/04/09 10:19 PM
Albuquerque, NM
GOAT Duster Offline
GOAT Duster  Offline
Albuquerque, NM
You have alot of work into that truck...I bet you could damn near make one from scratch by now...and blind folder at that. Looks great.
Re: My Journey: 1973 Dodge Power Wagon [Re: GOAT Duster] #246558
05/05/09 11:08 PM
05/05/09 11:08 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Thanks, guys. I'm learning something new everyday. I tried to put a penny held by a pair of needle nose pliers behind a hole in the body (trim hole) in order to weld it shut - copper, you know. Not gonna happen Johnboy! I melted the penny and the pliers went straight through. Yep, I need a copper spoon, duh.
But I'm having fun.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246559
05/05/09 11:10 PM
05/05/09 11:10 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Progress May 4 and 5, 2009.
Monday I welded up across the seams of the floorpan.
Tonight (Tues) I cut the sidewall piece for the left floor.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246560
05/05/09 11:11 PM
05/05/09 11:11 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Here is the piece after tack welding it in place.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246561
05/05/09 11:13 PM
05/05/09 11:13 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I'm working on my "stitching" method to keep the heat down while welding sheet metal. Welding 18 ga. to 18 ga. helped a bunch.
Here is the piece welded together.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246562
05/05/09 11:15 PM
05/05/09 11:15 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
After wire brushing, I noticed a few missed spots, so I fixed those.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246563
05/05/09 11:17 PM
05/05/09 11:17 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
After grinding down the welds, I touched up a few spots. I also ground down too much on the "nose" of the piece and had to re-weld it. After welding, grinding and brushing this is what I ended up with:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246564
05/05/09 11:20 PM
05/05/09 11:20 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I still have to drill more holes to attach it to the supports more securely and open up a hole to access the body mount boss, but that is for another day. I also started on the right side pan, but there are a few issues I have to correct on the body before I can install it.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246565
05/06/09 12:28 AM
05/06/09 12:28 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
But I'm having fun.
I took a piece of ¾" copper pipe and flattened it out to use as a spoon. It's worked pretty well for me, and it's been CHEAP!
Pennies aren't really copper anymore, as you might have noticed!
2 Demons...no, not my kids!
Re: My Journey: 1973 Dodge Power Wagon [Re: 4speeds4me] #246566
05/06/09 08:56 AM
05/06/09 08:56 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
4speeds4me, that is a great idea! Thanks for bringing that up. Now, where have I seen some spare copper pipe around here...
Mark
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246567
05/06/09 10:31 AM
05/06/09 10:31 AM
4speeds4me Offline
4speeds4me  Offline
Just remember that heat travels VERY quickly through copper, so if you're holding this by hand, it's going to get uncomfortable VERY quickly! DAMHIK!
Re: My Journey: 1973 Dodge Power Wagon [Re: 4speeds4me] #246568
05/16/09 10:17 PM
05/16/09 10:17 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I hear ya! It reminds me of that story of the guy that picked up a hot horseshoe right after it was forged and set to cool. After he threw it down on the ground quickly, the smith asked him if he was alright. He said, "Yeah, it just doesn't take me long to look at a horseshoe."
May 16, 2009 Progress
My family and I left for a wedding on Friday night (May 8th) in Tarkio, Mo., so I was gone last Saturday. Consequently, I did not get much done until last week. Since that week was busy, too (personal things and ASE certification tests (8) on Thursday - 3 hours in the fightin' chair!), I wasn't able to do much until today.
I did, however, experiment on ways to close up those pesky trim holes in the "B" pillar area.
Here are the holes:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246569
05/16/09 10:20 PM
05/16/09 10:20 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I used a piece of 18 ga. behind the holes to back up the thin sheet metal. The only mistake was using a magnet to hold it in place. Still, it came out OK with a minor amount of panel warping.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246570
05/16/09 10:22 PM
05/16/09 10:22 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I also had some "A" pillar rot down at the floor pan area, so I cut the damage out.
