Page 8 of 10 1 2 6 7 8 9 10
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246531
04/18/09 09:43 PM
04/18/09 09:43 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Week - April 13 - 18, 2009
I finally found a welder that fits my budget and that will do what I need. I purchased a Hobart 125 from Northern Tool. Right now, I'll use flux core, but I'll eventually get the kit to convert to a MIG - probably when get to the outer sheet metal on the body.
In the meanwhile, I continued the arduous task of clearing the cab from all paint, seam sealer, and loose rust.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246532
04/18/09 09:45 PM
04/18/09 09:45 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I also prepped the '73 dash by removing all paint. I'll paint it with some epoxy primer and the semi flat black paint. I'm still not sure of the outer body color, but the dash WILL be black!
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246533
04/18/09 09:50 PM
04/18/09 09:50 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Here is a catalog pic of the welder:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246534
04/18/09 11:03 PM
04/18/09 11:03 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Good job on bending the floor pan metal without a brake. Tough trick.
I can't afford this. mark
Re: My Journey: 1973 Dodge Power Wagon [Re: a12superbee] #246535
04/20/09 12:09 AM
04/20/09 12:09 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Thanks. I would have used my former bro-in-law's brake, but it was Saturday (they don't work Saturday) and 15 miles away. The first bend is easy - it's that second bend that's hard!
Mark
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246536
04/25/09 10:11 PM
04/25/09 10:11 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
April 25th, 2009.
I received the welder on Friday, the 24th of April. I test welded a few scraps of metal, enough to know I am going to have to practice before I tackle the floor pans!
So, I decided to build a welding cart (what else!?).
Here is what I spent today doing:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246537
04/25/09 10:12 PM
04/25/09 10:12 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Here's the final version:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246538
04/25/09 10:14 PM
04/25/09 10:14 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Fully loaded and ready to go, she looks like this:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246539
04/25/09 10:16 PM
04/25/09 10:16 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I still have to work out some issues with my welding. The last welds were crappy! Practice, practice, practice! I can't wait to get those floor pans in....
Mark
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246540
04/25/09 11:58 PM
04/25/09 11:58 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Not sure what the issues you are finding are, but I can tell you that when it comes to doing the floorpans, you won't be welding a continuous bead. Body metal is pretty thin, and the constant heat buildup will start to cause blowouts. Practice getting a good puddle in short (~1 second) bursts. Go slow, and keep it cool. There are some very talented metalworkers here that can give way better info than I but I will be happy to share what I can...
2 Demons...no, not my kids!
Re: My Journey: 1973 Dodge Power Wagon [Re: 4speeds4me] #246541
04/26/09 01:19 AM
04/26/09 01:19 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Yeah, you're exactly right. When welding the 1" tube to the 18ga. sheet metal on my cart, I could easily burn through if I wasn't careful. Another issue is the use of .030" Flux core. I know it's hated by many, but is a necessary evil in my case until I can procure the MIG kit in order to use .023" wire and gas.
Besides, after I'm done, no one will see the floor pans anyway.
Thanks for the tip on the short bursting. I should have some time next week to try it out when I begin installing the pans. If anyone else would like to share their own tips, I would (absolutely!) love to hear them as well!
By others shared experiences we learn and grow!
Mark
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246542
05/02/09 11:18 PM
05/02/09 11:18 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Progress, May 2nd, 2009
After spending a weekend welding a cart for my new HH125, I decided it was time to get back to work on the cab.
With two of my sons, Levi and Matthew, I began to make the final preparations for installation of the left floor pan.
I made the front divots:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246543
05/02/09 11:19 PM
05/02/09 11:19 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Next, I trimmed the front flange to mate with the A pillar.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246544
05/02/09 11:21 PM
05/02/09 11:21 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
The rear pan had to be trimmed, then bent to accommodate the rear contours of the remaining floor of the cab.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246545
05/02/09 11:22 PM
05/02/09 11:22 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Here is the panel, ready for fitting and 'final' trimming.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246546
05/02/09 11:25 PM
05/02/09 11:25 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
There were some other areas of rust that had to be dealt with. First, the rear seat belt support cover sheet metal had rust, so we cut it out.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246547
05/02/09 11:26 PM
05/02/09 11:26 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
The A pillar next to the floor had to be cut out, also.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246548
05/02/09 11:27 PM
05/02/09 11:27 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
After this, we began fitting the panel.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246549
05/02/09 11:28 PM
05/02/09 11:28 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
The rear fitment.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246550
05/02/09 11:30 PM
05/02/09 11:30 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
We're finally ready to tack this baby down!
