Page 2 of 10 1 2 3 4 9 10
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246411
03/08/09 01:26 AM
03/08/09 01:26 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I decided to do something about the bed. I needed a low cost alternative to a bed liner so I chose Herculiner.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246412
03/08/09 01:27 AM
03/08/09 01:27 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
This stuff...
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246413
03/08/09 01:30 AM
03/08/09 01:30 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Actually, it works pretty good. Certainly not as tough as Rhino liner or similar products, but not near as expensive, either. I used POR-15 on the surface before I applied the Herculiner.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246414
03/08/09 01:33 AM
03/08/09 01:33 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
And now, the Herculiner.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246415
03/08/09 01:36 AM
03/08/09 01:36 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I POR'ed the floor to make it last just a bit longer. Hey, anything helps!
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246416
03/08/09 01:39 AM
03/08/09 01:39 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
And this is how we stood (before the Herculiner) after the body change. It would last until December 2007, a day that would live in infamy...
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246417
03/08/09 01:46 AM
03/08/09 01:46 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
In December of 2007, we suffered a severe ice storm. As a result, a tree fell on my Power Wagon. It severely damaged my bed, and got the cab as well.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246418
03/08/09 01:47 AM
03/08/09 01:47 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Another view of the truck.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246419
03/08/09 01:53 AM
03/08/09 01:53 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I bent the bed back with a porta-power. I searched for and found another bed and cab for my truck.
The city Gestapo called me out for my "unlicensed" truck in the back yard, so I swapped out the bed a few weekends ago. I obtained a hood when I got the truck bed and cab.
I wanted to add the birdbath hood, so I went ahead an painted it and stuck it on (with the original '73 cowl). I like it!
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246420
03/08/09 01:57 AM
03/08/09 01:57 AM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
This is where we sit thus far. Today, March 7th, Saturday, I removed the cab from the donor truck. I begin work in earnest to make it ready to be my new cab. Pics to follow.
Remember, in all of this, my intent is NOT to make a show truck, but to have a solid work truck. My hat is off to those who meticulously restore their trucks to perfection. They are works of beauty. However, my intent is not to build something like that, but to enjoy, drive, and work my truck. And it really does love to work!
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246421
03/08/09 03:55 AM
03/08/09 03:55 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
That was a cool read!
2 Demons...no, not my kids!
Re: My Journey: 1973 Dodge Power Wagon [Re: 4speeds4me] #246422
03/08/09 03:26 PM
03/08/09 03:26 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Thanks!
As I was looking over the information this morning, I remembered quite a lot that I have done over the past several years, especially to the drivetrain.
So I'm flashing back to a few months after the changeover; it's probably 2005 or 2006. Yeah, it all blurs after a few years!
Earlier in its life, the truck was abused by the sons of the man I bought the truck from. They parked it in a creek for a while and didn't changed the fluids afterward. Needless to say, the rear 8-3/4 3.90 gears were pitted and needed replacement. So I pulled the pumpkin to change the gears...
Side note: This truck is a half ton! Notice the number of spring leaves this truck has! That's what, 8 including the lower? I have the broadcast sheet and it lists a special spring package - SR4701 RR SPRG. I've seen 3/4 ton trucks that have less spring! I suppose it was for a camper or some such purpose. It will hold a load, too.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246423
03/08/09 03:30 PM
03/08/09 03:30 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
The teardown results? Rust!
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246424
03/08/09 03:43 PM
03/08/09 03:43 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
The carrier was pretty rusty as well. I opted for a good used carrier with spider gears. I didn't go posi because of cost constraints at the time.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246425
03/08/09 03:45 PM
03/08/09 03:45 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I cleaned up the housing, purchased a Yukon gear set from Randy's Ring and Pinion in Washington state, and set her up.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246426
03/08/09 03:51 PM
03/08/09 03:51 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Of course, the axle bearings were shot and needed replacement, so I replaced them, too. I cleaned rust out of the housing and put new seals in. Curious animal, the 8-3/4. Last year, due to water intrusion, I had to go back into the axle bearings. THIS time I used the updated "Green" bearings. MUCH better. I heartily recommend them for anyone redoing an 8-3/4 axle.
Due to the new pinion, I changed the yoke as well.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246427
03/08/09 03:55 PM
03/08/09 03:55 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I almost forgot. Here's a pic of the old ring gear. It was worn so much the drive face of the teeth were SHARP. A friend of mine suggested in leaving it alone and stuffing it with bananas, peelings and all... NAH! Let's do it right!
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246428
03/08/09 03:59 PM
03/08/09 03:59 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I moved up the driveline to the transfer case. Here, I was shocked and disappointed all over again (but not surprised).
I present: the NP205 Transfer case.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246429
03/08/09 04:07 PM
03/08/09 04:07 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I really needed to replace many of the gears. The bearing surfaces were pitted. I opted, however, to rebuild the case using new bearings and seals, and find a complete unit later, rather than chase down all of the necessary gears and shafts.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246430
03/08/09 04:08 PM
03/08/09 04:08 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Shaft bearing pits.
