Page 10 of 10 1 2 8 9 10
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246571
05/16/09 10:25 PM
05/16/09 10:25 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
After cutting a fresh 18 ga. patch, I welded it in place.
I also cut out the rot at the rear seat belt support. I'll need to cut out a section beyond that, but I cut out enough to get the floor pan in today.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246572
05/16/09 10:27 PM
05/16/09 10:27 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
With these tasks done, I focused on bending the floor to the new configuration.
Here are the floor divots. Because these are longer, they caused the metal to pull more instead of stretch (as in a die), so I had to massage the panel to get it back into proper proportion after the divots were struck.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246573
05/16/09 10:30 PM
05/16/09 10:30 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I also shaped the right side of the pan, and the rear of the pan to match existing contours. In addition, I marked and pre-drilled weld holes to make it simpler to attach to the floor supports. I'll still have to drill and complete the other side.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246574
05/16/09 10:33 PM
05/16/09 10:33 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I clamped, tacked, then began installing the pan. I seem to be getting a bit more experienced with the welding. My beads aren't nearly as high as the other side (less grinding) and penetration is good. I slowed WFS and increased gun speed a tad bit (less heat on the area).
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246575
05/16/09 10:36 PM
05/16/09 10:36 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
The stitching method is also working well. Who knows? I may make a novice welder, yet!
Here is a full view of the job so far:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246576
05/19/09 11:07 PM
05/19/09 11:07 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
May 18 and 19 Progress:
I spent time after work Monday and Tuesday working on the cab.
I filled in the right side trim holes, welded the floorpan to the rocker panel assembly, and welded the front seam of the floorpan more completely.
The trim holes:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246577
05/19/09 11:08 PM
05/19/09 11:08 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
The rocker seam:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246578
05/19/09 11:09 PM
05/19/09 11:09 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
I also welded the door jamb foot back onto the rocker panel - it broke loose somehow.
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246579
05/19/09 11:11 PM
05/19/09 11:11 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
Today (Tuesday) I cut the upper level of the right side floorpan and attached it to the existing floor. I drilled and welded the pan to the floor support, cut out the right wing panel for the floor pan and installed it, too.
The right side pan assembly installed:
Re: My Journey: 1973 Dodge Power Wagon [Re: 734x4PW] #246580
05/19/09 11:13 PM
05/19/09 11:13 PM
Joplin, MO
734x4PW Offline OP
734x4PW  Offline OP
Joplin, MO
My wife dropped by this evening and snapped a shot of me working on the cab.
