#2463420 - 03/08/18 08:15 PM msd retard 8972 questions
plycuda Offline
Loc: Fredericksburg Va
I hooked up the box and my timming is dropping like 20 degrees. from unhooking the crank trigger to the 7al to connecting to the retard box. I have zero in all 3 retards. I have the same box on my other car and I don't remember it changing at all. until you ground the wires for it to retard. I called msd and he told me to make sure the 3 wires for the retard are grounded. which I rechecked and they are. which shouldn't matter if I have zero in all 3 retard slots. anyone else have this box have to move the timming this much hooking up the box.I don't have the start retard hooked up either. thks Danny
#2463493 - 03/08/18 09:54 PM Re: msd retard 8972 questions [Re: plycuda]
Dave Hall Offline
Loc: Cotati, CA
Is it the 8975 digital or the 8970 3-stage? MSD site does not list 8972??? Why unhook the crank trigger?
#2463504 - 03/08/18 10:10 PM Re: msd retard 8972 questions [Re: Dave Hall]
plycuda Offline
It's 8970 my son's was the 8972. I disconnect the retard box and hook the crank trigger wires back to the 7al and the timming changes 20 plus degrees
#2463542 - 03/08/18 11:22 PM Re: msd retard 8972 questions [Re: plycuda]
slantzilla Offline
Loc: Park Forest, IL
Make sure the trigger wires are not hooked up backwards. I did it on a distributor and it changed timj ng like 25°.
#2463578 - 03/09/18 02:35 AM Re: msd retard 8972 questions [Re: plycuda]
Dave Hall Offline
Loc: Cotati, CA
The basics of it are that you interrupting the signal from the crank trigger to the 7al-2. You now plug the crank signal into the retard then to the 7al-2 with the white points wire. You no longer use the poles for the trigger on the ignition box. If it changes the timing some, you need to reset the crank trigger to the timing you want and re phase the rotor on the dist.
#2464004 - 03/09/18 06:07 PM Re: msd retard 8972 questions [Re: Dave Hall]
plycuda Offline
I understand this. I have had crank triggers for over 30 years. but I haven't seen the timing change that much hooking up a retard box. I called msd again and he said the box is probably bad.
#2464100 - 03/09/18 09:07 PM Re: msd retard 8972 questions [Re: plycuda]
Dave Hall Offline
Loc: Cotati, CA
Well crap! That sucks! I had a difference of about 10 degrees switching from an al-2 to an al-3 so I had seen something like that before...
#2464115 - 03/09/18 10:22 PM Re: msd retard 8972 questions [Re: Dave Hall]
plycuda Offline
I can adjust the crank trigger back up to adjust for the drop in timing but I'm worried if something is wrong and it goes back up when I decide to bottle it and I melt it down
#2464160 - 03/10/18 12:32 AM Re: msd retard 8972 questions [Re: plycuda]
Dave Hall Offline
Loc: Cotati, CA
If MSD says it's NFG, can they fix it?
#2465126 - 03/12/18 08:56 AM Re: msd retard 8972 questions [Re: plycuda]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Call Pat Collins at TechWest Racing in NC. He repairs MSD products and is great to deal with. 704-995-4286
I'm not 100% sure (been a while), but I think I had the same thing happen to mine and everyone I asked said it was OK. I use the same 3 stage retard box w/ a 6AL and crank trigger.
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
25,346 Registered Members
190,221 Topics
1973 Satellite Sedan
by moparmike1
06/22/18 05:46 AM
1969 Plymouth Road Runner
by tomsjack
06/22/18 04:47 AM
CARBON FIBER HOOD
by A/MP
06/22/18 12:22 AM
TUNING W2 HEADS
by A/MP
06/22/18 12:15 AM
