#2463005 - 03/08/18 08:06 AM Cuda rear quarter patch panel
Purestocker Offline
Loc: grand rapids mi. usa
Hello all, I am repairing the left rear quarter panel behind the tire on my 71 cuda, I have ordered a few reproduction panels before and have been less than pleased with some, but sometimes cheaper can be better, AMD gets 160.00 for the patch and goodmark is only 60.00? Is there a big quality difference? Does one work out better than the other? The last AMD parts I bought were Cuda Fenders and a header panel and the fit was poor on the fenders, side market was stamped in crooked and the header panel was 1/4 wider on one side than the other? Don’t get me wrong you can make all of these work with time spent on them but I paid more for these pieces expecting a little better, thanks for the input in advance
#2463130 - 03/08/18 12:26 PM Re: Cuda rear quarter patch panel [Re: Purestocker]
AARCONV Offline
Loc: NEW JERSEY
Just make sure the panels have the rear valance stamped into it
#2463188 - 03/08/18 02:29 PM Re: Cuda rear quarter patch panel [Re: Purestocker]
Morty426 Offline
Loc: Sacramento CA
Everything I ever got from Goodmark went into a trash can
#2463487 - 03/08/18 09:50 PM Re: Cuda rear quarter patch panel [Re: Purestocker]
Silver70 Offline
Loc: Rust Belt, SW PA
I use a lot of goodmark panels and very happy with it. It all needs work to be perfect. I couldn't get full goodmark cuda quarters last summer and used amd... they did not fit right to the original deck filler. Also thicker than oem which can be an issue also. Goodmark floors from rockauto are less than half of amd and same thickness as oem.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
25,637 Registered Members
195,742 Topics
1965 Plymouth Fury go cart
by bigdad
12/18/18 09:25 AM
CREW CAB Dodge pickup custom $19,900 --Michigan
by bigdad
12/18/18 09:13 AM
Some of Our Favorite Mopars (Cars & Engines) From PRI 2018
by Rustymuscle
12/18/18 09:10 AM
rear coil over springs
by dragon
12/18/18 09:09 AM
