#2463446 - 03/08/18 09:01 PM Specs on this Crower cam?
Jeff_383 Offline
Loc: Pittsburgh, Pa
Can anyone give me the specs on this cam? I can't seem to find them anywhere.
#2463469 - 03/08/18 09:36 PM Re: Specs on this Crower cam? [Re: Jeff_383]
71birdJ68 Online   content
Loc: Morristown Tn.
Can't read the part number.
#2463474 - 03/08/18 09:39 PM Re: Specs on this Crower cam? [Re: Jeff_383]
Loc: Bend,OR USA
Call Crower tech. @ 619-661-6477 to get the straight scoop up
They're very helpful scope
#2463483 - 03/08/18 09:45 PM Re: Specs on this Crower cam? [Re: Jeff_383]
Jeff_383 Offline
Loc: Pittsburgh, Pa
#80132
#2463516 - 03/08/18 10:40 PM Re: Specs on this Crower cam? [Re: Jeff_383]
Loc: Bend,OR USA
Call them with all the numbers etch into the ends of the cams scope , that will give them the lobe separation angle and probably which lobes are on that cam thumbs
#2463549 - 03/08/18 11:38 PM Re: Specs on this Crower cam? [Re: Jeff_383]
Jeff_383 Offline
Loc: Pittsburgh, Pa
No numbers on cam
#2463568 - 03/09/18 12:53 AM Re: Specs on this Crower cam? [Re: Jeff_383]
451Mopar Offline
Loc: Aurora, Colorado
Originally Posted By Jeff_383
#80132
Most of the #80xxx, and #81xxx numbers are the lifter, spring, retainer kits? Re-looking at the photo, it says component kit which is the lifters, springs and retainers, but not the cam. In the 1980 price guide it says it cost $297.00 List, $207.90 User.
I looked through the 1980 Catalog I have, but it does not show that part number? It may have been a Component kit part number before 1980?
If you have a block to put the cam in, and a cam degreing kit, you cam measure the specs off the cam.
#2463577 - 03/09/18 02:33 AM Re: Specs on this Crower cam? [Re: Jeff_383]
Loc: Bend,OR USA
No numbers on cam
If it doesn't have Crower etched into the cam with the grind number and LSA on it then it is probably not a Crower cam, even though it was in a Crower box shruggy work
25,628 Registered Members
195,543 Topics
Looking For Kick Down Linkage Experience
by Rodder
12/11/18 11:12 PM
Battery ID from broadcast sheet
by 340cpe
12/11/18 10:47 PM
Lower cylinder damage,ok to run?
by RTSrunner
12/11/18 10:14 PM
77 charger. midnight charger?
by moparvinson
12/11/18 10:06 PM
