Page 1 of 2 1 2 >
#2444209 - 01/31/18 05:13 PM Carter Mechanical Fuel Pump M6903 Pressure Fluctuation
65Fury440 Offline
Loc: Spring Hill Fl
I just installed this fuel pump as an upgrade.
Worked fine for the first 30 miles, now it drops pressure for a few seconds intermittently.
The inlet fittings are tight from the tank
The tank is vented
Pushrod length is 3.120.
Wouldn't the pushrod lose pressure at higher RPM if too short?
No problems before other than limited delivery.
I took it apart to re orient fitting location, did not see anything amiss, went back together fine.
Pump drops pressure for a couple seconds and slowly comes back up at idle or slightly above
Any ideas?
https://www.summitracing.com/parts/crt-m6903
#2444216 - 01/31/18 05:24 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
Sport440 Offline
Loc: Canton, Ohio
Maybe its just your floats opening and closing showing the fluctuation. How are you reading the PSI?
You may have line or filter restrictions going on as well maybe enhancing the appearance of the psi fluctuations.
I ran that pump as well, but it was the higher 9 psi version and it couldn't keep up with 550 hp.
#2444294 - 01/31/18 07:35 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
Loc: Lincoln Nebraska
I would toss the old pump back on for a test (& see if it acts up the same at the psi it provides). If no "drop" then it'd about have to be the pump itself, if it drops psi then obviously upstream (toward the tank) or downstream (to/in the carb) from the pump itself there's a problem. Holler what it ends up being. the old pump was fine as far as no pressure drop I am assuming so I am thinking the pump valves
#2444364 - 01/31/18 08:55 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
markz528 Offline
Loc: Milford, OH
I could never get those pumps to work. I gave up and went electric. When I put the original motor back in I put the stock one back on.
67 Coronet 500 (street car) 13.300 @ 101.75 mph
#2444430 - 01/31/18 11:03 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: markz528]
Agreed, it's called the Carter Curse.
#2444437 - 01/31/18 11:14 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
Diplomat360 Offline
Loc: Windsor, ON, Canada
Hmm...interesting, very similar to what I saw with my M6902 pump. Is the M6903 a newer version of the M6902?
Oh, on my end, I never figured out what was causing this. I actually tested out two pumps (both were brand new), both showed the same behaviour. Besides, my bigger concern, and focus point, at that time was that I was seeing low PSI at all times...turned out I had plumbed the fuel filter incorrectly having put it BETWEEN the tank and the pump inlet. Once I moved the filter to AFTER the pump the PSI picked-up.
1980 Dodge Diplomat Coupe, 360-4bbl, 727, 3.91 SG motivated sleeper! 1981 Dodge Diplomat Coupe, /6 38K mi. survivor car, awaiting restoration.
#2444442 - 01/31/18 11:18 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
MoparBilly Offline
Loc: Phoenix, AZ
Is the engine starving for fuel? Vapor locking? I have the same pump on my 440, 67 B-body with stock 5/16th line, feeds both the 750 Holley and the 160 shot of nitrous, and it's been 11.24-122. If the car doesn't fall on it's face, I wouldn't sweat the pressure gauge moving around a bit.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
#2444449 - 01/31/18 11:30 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: MoparBilly]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
I was having a weird issue on a new mechanical fuel pump and can't remember who said it to me but they said "do you really believe anyone cares about the quality of a mechanical pump they are selling these days?"
Edited by sixpackgut (01/31/18 11:33 PM)
#2444929 - 02/01/18 08:26 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
therocks Offline
Its Lost
Loc: Niles , Ohio
We had 3 carter all hipo new.2 BBs and 1 Sb.One never worked out of the box.1 was on the 413 for like 100 miles and the spring on the arm popped and it quit.Lucky we got the spring out of the pan.1 ran for like 1 hour on my 440.went back to my hipo Holey pumps.Had one I bought in the 70s that ran better than a new carter.Now we run all Holleys.rocky
Chrysler Firepower
#2446324 - 02/04/18 02:06 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
GTX MATT Offline
Loc: CT
I have that pump with a 3/8 line on my 440 in my '67. Pressure drops to 3 psi by the top of 1st gear. If you wack the throttle idling it'll drop from 7 to 6...
#2461277 - 03/04/18 10:31 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
65Fury440 Offline
Loc: Spring Hill Fl
I had a chance to pull the pump off and apart.
The diaphram and spring look good.
I have a cowl mounted gauge, the weird part is the problem happens at low rpms, no real way to reproduce it, just happens when it wants.
The whole fuel system is new from the 3/8s sending unit up to the carb.
I am thinking of replacing it with the Edelbrock pump just for the simple fact it has 3.8 fittings.
Does anyone have good or bad experiences to report?
http://www.manciniracing.com/mechanical.html
#2461293 - 03/04/18 10:52 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: markz528]
StealthWedge67 Offline
Loc: Puyallup, WA
I’ve been using a 6903 pump for years with good success. My guage used to move a round a little (3-7), but never dropped to zero. Since going to 1/2” line, it now stays much more stable. Like Billy said; if the car isn’t running out of fuel, I wouldn’t worry about it too much.
LemonWedge - Street heavy / Strip ready - 11.32 @ 117
#2461320 - 03/04/18 11:45 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
65Fury440 Offline
Loc: Spring Hill Fl
UGH, I searched the Edelbrock pump, they have pressure problems also,
There's not much out there for a BBM.
I'm worried it is going to completely quit.
What should I look for when looking at the valving in the pump?
#2461794 - 03/05/18 09:43 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
Brewzer67 Offline
Loc: WI
I just saw a used Clay Smith mechanical pump for sale on Facebook marketplace. I have been running one for 10 years with no issue. It has supported 600 hp so far and I'm hoping it will support the 775 I'm shooting for.
#2461830 - 03/05/18 10:39 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
65Fury440 Offline
Loc: Spring Hill Fl
Got a link?
#2462373 - 03/06/18 09:45 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
Brewzer67 Offline
Loc: WI
Sorry, by time I found it again it was sold. I figured it would go pretty quick. Since they are so hard to get these days they move pretty quick if they are priced reasonably.
#2462714 - 03/07/18 03:41 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
lewtot184 Offline
Loc: usa
this is typical of mech pumps. they're pulse pumps, not constant pressure/flow. fluctuations will be more noticeable the lower the rpm. vapor separator return lines will make the pulses more noticeable. rev the engine up a little and see if the pulses stabilize to a steady pressure.
#2463468 - 03/08/18 09:35 PM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
65Fury440 Offline
Loc: Spring Hill Fl
When it does drop out is when the RPMs are low, for about 5 seconds.
Even when I speed it up to maybe 1500, it stays low, then comes back up to about 6.5 psi, It's weird.
#2463606 - 03/09/18 07:45 AM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
Tommy D Offline
Loc: Harleysville, PA USA
I've run this pump at the rear, and a Carter mechanical up front for years in our race car and in my street car (10.80/11.07). I have a cowl-mounted gauge as well. My pressure fluctuates at low rpm, but is steady at 7PSI at 6800 RPM through the traps. I drive the same setup on the street and never had a failure. Probably been 20 years and 5000 miles. I do not typically drive it long distances. Maybe 50 miles at a time. I run a toggle switch under the dash and shut it off at lights and when cruising through town. Then it runs on the mechanical pump alone. I wouldn't sweat it.
#2463634 - 03/09/18 08:47 AM Re: Carter Mechanical Fuel Pump M6903 Pressure Fluctuation [Re: 65Fury440]
Mattax Offline
Loc: Phila. Pa.
At low rpm, if the carb bowls need filling, the pressure may be a little low. I'd expect to see 3-4 psi, be somewhat concerned about pump or supply line if its 2 psi, and very concerned if its 0 - 1 psi.
Going down the track, I'd like to see 3 psi or higher.
maybe an explanation will help.
With diaghram type pump potentially flow more with increasing rpm.
In general more valves inside increase the flow possible.
Pressure is controlled by the spring. The pump arm pulls the diaphram up, but the spring pushes the diaphram down. When the fluid pressure is high enough, the spring can't push down. This cuts off the pressure from increasing.
So pressure on the gage is a combination of these.
With the smallblock, I had good luck with the Holley 110/Kieth Dorton series mechanical pumps. But of course mine was made 10-15 years ago, could be different now. However fuel pumps for small blocks have space limitations when running passenger side inlet water pumps. With a big block there should room to run a 6 valve pump.
If you really get stuck, contact Ryan Brown Racing. They deal with mechanical pumps as they have a lot of circle track customers. I had them test some small block pumps for me.
Seems to be some trouble uploading pics this morning.
Go here - about 3 post in row here with pump graphs and photos
https://www.tapatalk.com/groups/racingfu...1032.html#p9568
Below is a flow graph of the 110 mechanical pump from Holley's catalog. (It used to be on a webpage, now you have to find the catalog.)
Freeflow is pretty much meaningless, even though that's what they all advertise. There's always some resistance in the line and inlet valve.
Edited by Mattax (03/09/18 08:56 AM)
Page 1 of 2 1 2 >
25,492 Registered Members
193,090 Topics
1969 Plymouth Road Runner
by tomsjack
09/24/18 03:37 AM
what app uses a 5/16 (.312") 2.02 intake valve
by RapidRobert
09/24/18 01:04 AM
"central tool" micrometers: good/average quality?
by RapidRobert
09/24/18 01:00 AM
73 Charger project
by Neil
09/23/18 10:59 PM
