#2463195 - 03/08/18 02:40 PM 69 Road Runner Trim
cbusters Offline
Loc: Florida
I am installing the rear convertible top trim around the opening in front of the Dutchman Panel. What hardware is used to attach these clips to the lip around the body opening? Thanks!
#2463449 - 03/08/18 09:11 PM Re: 69 Road Runner Trim [Re: cbusters]
PurpleBeeper Offline
Loc: Chicago
I "think" you might have the wrong clips, but I'd have to take a closer look at mine. The trim in front of the Dutchman panel, in fact all the convertible trim around the top, is attached by screws coming up & in from underneath. I believe the holes in the trim clips are more centered in the trim (again, I have to look). There are holes along the body line "lip" where the screws go.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
#2463543 - 03/08/18 11:24 PM Re: 69 Road Runner Trim [Re: PurpleBeeper]
cbusters Offline
Loc: Florida
I do have holes in the "pinched" area. The fasteners pass through those holes into the clip in the picture that slides into the stainless trim that is assembled as shown. I am missing the description of that one part that fastens them.
#2464932 - 03/11/18 07:17 PM Re: 69 Road Runner Trim [Re: cbusters]
Loc: Chicago
Ok, I double checked my extra convertible trim & you have the correct clips. What holds those onto the car is simply "machine screws" that you can buy at a hardware store.
The factory ones are slightly beveled at the tip to make them easier to install, but nobody will ever see the screws, so hardware store is fine in my opinion. Just be SURE the screws you get aren't too long or you will dent the trim tightening them down. The screws come up from under the pinchweld lip, through those holes, into the holes in your trim clips.
You might need to custom-cut some hardware store screws. If so, then maybe run a die up on the screw, cut them in a convenient way, maybe even bevel them slightly, and back the die off the screw to clean up the threads you just cut.
Edited by PurpleBeeper (03/11/18 07:19 PM)
#2465018 - 03/11/18 10:00 PM Re: 69 Road Runner Trim [Re: PurpleBeeper]
cbusters Offline
Loc: Florida
Thanks, I located someones spare set yesterday and found phillips head machine screws in the pot metal pieces and phillips head sheet metal screws in the clip parts and they screwed in the slot part of the clips.
25,635 Registered Members
195,668 Topics
how deep a hole should 4 speed crank be
by moparpro
28 minutes 21 seconds ago
Rocker ratio questions
by fourgearsavoy
54 minutes 13 seconds ago
Thinning the herd. Bye bye Ramcharger. However dot dot dot
by 330Scott
Today at 10:48 AM
Gen III Swap or 360?
by Nroma227
Today at 10:44 AM
