Specs on this Crower cam? #2463446
03/09/18 12:01 AM
03/09/18 12:01 AM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
Can anyone give me the specs on this cam? I can't seem to find them anywhere.
Re: Specs on this Crower cam? [Re: Jeff_383] #2463469
03/09/18 12:36 AM
03/09/18 12:36 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Can't read the part number.
Re: Specs on this Crower cam? [Re: Jeff_383] #2463474
03/09/18 12:39 AM
03/09/18 12:39 AM
Call Crower tech. @ 619-661-6477 to get the straight scoop up
They're very helpful scope
Re: Specs on this Crower cam? [Re: Jeff_383] #2463483
03/09/18 12:45 AM
03/09/18 12:45 AM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
#80132
Re: Specs on this Crower cam? [Re: Jeff_383] #2463516
03/09/18 01:40 AM
03/09/18 01:40 AM
Call them with all the numbers etch into the ends of the cams scope , that will give them the lobe separation angle and probably which lobes are on that cam thumbs
Re: Specs on this Crower cam? [Re: Jeff_383] #2463549
03/09/18 02:38 AM
03/09/18 02:38 AM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
No numbers on cam
Re: Specs on this Crower cam? [Re: Jeff_383] #2463568
03/09/18 03:53 AM
03/09/18 03:53 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted By Jeff_383
#80132
Most of the #80xxx, and #81xxx numbers are the lifter, spring, retainer kits? Re-looking at the photo, it says component kit which is the lifters, springs and retainers, but not the cam. In the 1980 price guide it says it cost $297.00 List, $207.90 User.
I looked through the 1980 Catalog I have, but it does not show that part number? It may have been a Component kit part number before 1980?
If you have a block to put the cam in, and a cam degreing kit, you cam measure the specs off the cam.
Re: Specs on this Crower cam? [Re: Jeff_383] #2463577
03/09/18 05:33 AM
03/09/18 05:33 AM
No numbers on cam
If it doesn't have Crower etched into the cam with the grind number and LSA on it then it is probably not a Crower cam, even though it was in a Crower box shruggy work
