#2463197 - 03/08/18 02:45 PM 69 Dart Rear wheel fitment
SSDart Offline
Loc: Moparts
I'm trying to figure out what rim best fits the rear of my Dart?
Leaf springs moved up against the frame rail(not under) Stock Axle width.
I remember years ago being able to fit a 28.5 X 9 Firestone under the car with a 7 inch Auto Drag. ( I can't remember the backspace. )
I'm thinking a 15 X 7 3 1/2 back space would work...
Anyone care to share there experience with this?? TIA
#2463253 - 03/08/18 03:55 PM Re: 69 Dart Rear wheel fitment [Re: SSDart]
Forest Offline
Loc: SE Washington
I would guess it would want closer to a 4 1/2" to 5" backspace with either a 7-8" wide wheel...
#2463309 - 03/08/18 05:34 PM Re: 69 Dart Rear wheel fitment [Re: SSDart]
Sammy Offline
Loc: Wind Gap,Pa.
15 x 8 with 4.5 back spacing 29"x 10.5 tire
#2463430 - 03/08/18 08:36 PM Re: 69 Dart Rear wheel fitment [Re: SSDart]
justinp61 Offline
Loc: W. Kentucky
With my springs moved in 3/4" and the rear end moved back 1/2" I ran a 15 X 8 with a 5.5" bs and a 275 radial.
#2463440 - 03/08/18 08:49 PM Re: 69 Dart Rear wheel fitment [Re: SSDart]
buildanother Offline
Loc: chicagoland,usa
Years ago I put some 8x26 slicks on lil red/warlock 15x8's and fit was decent after trimming a wee bit of the lip up above.
#2463845 - 03/09/18 01:52 PM Re: 69 Dart Rear wheel fitment [Re: buildanother]
SSDart Offline
Loc: Moparts
I ordered Billet Specialties 15X 8 5 1/2 B.S. today.
Next is my front dilemma Time to get rid of the 4 inch bolt pattern
#2464118 - 03/09/18 10:29 PM Re: 69 Dart Rear wheel fitment [Re: SSDart]
Forest Offline
Loc: SE Washington
I think you will be happy with that choice.
You can ordered a Wilwood or Strange front disc conversion for whatever spindle you currently have. May be easier than trying to find a good factory setup...
#2464155 - 03/10/18 12:06 AM Re: 69 Dart Rear wheel fitment [Re: SSDart]
Loc: Bend,OR USA
If your wanting to go cheap the 1973 to 1976 stock OEM A body disc brakes (4.5 inch bolt pattern with bigger wheel bearings) with the upper A arms and lower control arms bolt right on up scope
#2464334 - 03/10/18 01:26 PM Re: 69 Dart Rear wheel fitment [Re: Cab_Burge]
68DART360 Offline
Loc: Easton, PA
Cab_Burge has the right idea. That's the way to go for cheap. I found a complete setup off a valiant in a junkyard and it had new brake rotors and pads!
#2464466 - 03/10/18 06:24 PM Re: 69 Dart Rear wheel fitment [Re: Sammy]
StrkrDart69 Offline
Loc: Illinois
This is my combo.
#2464679 - 03/11/18 10:38 AM Re: 69 Dart Rear wheel fitment [Re: Forest]
CHAPPER Offline
Loc: Belpre,Ohio
I used the Strange kit. Went from '72-'73 A-body factory disc setup and lost over 50 lbs too. !!!
If you like drag racing, support your local track.
#2469911 - 03/21/18 05:29 PM Re: 69 Dart Rear wheel fitment [Re: Cab_Burge]
SSDart Offline
Loc: Moparts
Thanks Cab I'm doing the 65 Mustang Disk conversion for now...
25,628 Registered Members
195,543 Topics
Looking For Kick Down Linkage Experience
by Rodder
Yesterday at 11:12 PM
Battery ID from broadcast sheet
by 340cpe
Yesterday at 10:47 PM
Lower cylinder damage,ok to run?
by RTSrunner
Yesterday at 10:14 PM
77 charger. midnight charger?
by moparvinson
Yesterday at 10:06 PM
